Product Number/Description | Qty 数量 |
Agilent 7820A gc System Agilent 7820A 气相色谱系统 | |
G4350A 161 | 2 |
Split/splitless inlet with EPC 分流/不分流进样口,带EPC | |
G4350A 210 | 1 |
FID for Packed & Capillary Column 氢火焰检测器,带EPC,配填充和毛细柱 | |
G4350A 231 | 1 |
Electron Capture Detector 微池电子捕获检测器,带EPC | |
G6714AA | 1 |
EZChrom Elite Compact Software Controls a max. of 2 Inst.EZChrom软件 | |
19199M | 1 |
Install Kit for gcs w/out Gas Purifiers 气相色谱仪安装工具包(不包括气体净化器) | |
BHT-2 | 1 |
Trap, Big Hydrocarbon, 1/8 in 烃类捕集阱 | |
OT3-2 | 1 |
Trap, O2/H2O, 1/8 in 氧/水分捕集阱 | |
5190-1483 | 2 |
Syringe, 10.0 uL, FN, bevel tip 手动进样针 | |
G4350A 361 | 1 |
1 year std. consum. kit for Capillary 用于毛细柱的1年消耗品包(标准) | |
5182-0553 | 1 |
Screw cap and clear vial kit 100/PK 螺纹口瓶盖和透明样品瓶套装,100/包 | |
5183-4757 | 1 |
Non-Stick BTO Inlet Septa 11mm 50 pk 11mm 低流失不粘连进样隔垫, 50/包 | |
5080-8853 | 1 |
Ferrule Graphite 320um 0.5mm id 10/PK 石墨密封垫圈,适用320um 0.5mm 内径,10/包 | |
5183-4712 | 1 |
Lnr,gen purp split/spltls,tpr,glswl,deac 通用分流/不分流衬管,单细径锥,带玻璃毛,脱活 | |
19091J-433 | 1 |
HP-5 30m, 0.25mm, 0.25u毛细管柱(非极性) | |
123-1364 | 1 |
DB-624 60m, 0.32mm, 1.80u DB-624 60m柱(专为挥发性优先污染物和残留溶剂的分析而设计) |
