这是Materials Science and Technology的投稿网址:http://mst.edmgr.com/
以下是我投稿的稿件信件摘录如下:
这是我注册成功的:
Dear Mr. yangThank you for registering for the Editorial Manager online submission and peer review tracking system for Materials Science and Technology.Here is your username and confidential password, which you need to access the Editorial Manager at http://mst.edmgr.com/.。。。。。。。。
这是我投稿的PDF成功生成
Dear Mr. yangThe PDF for your submission "Tungsten Arc Welded Magnesium Alloy AZ31B Plates" is ready for viewing. Your PDF must be approved in order to complete the submission process and send the manuscript to the Materials Science and Technology editorial office. Thank you for your time and patience.
这是文章编号
Dear Mr. yangYour submission "。。。。" to Materials Science and Technology has been assigned the manuscript number: MST1。。。.
The paper is now with an Editor and we will contact you again once referees' comments are received. You will be able to check on the progress of your paper by logging on to Editorial Manager as an author.
Thank you for submitting your work to this journal.
这是评审意见;
We now have referees' comments on the above paper. I am pleased to tell you that the work is of interest, but regret to say that the paper is not considered suitable in its present form for publication in Materials Science and Technology. The reasons are detailed in the comments below. You will see that a number of general and specific points are mentioned which necessitate extensive rewriting of the paper. Please consider how you wish to proceed. If you are able to revise the paper extensively, to deal in full with all the points mentioned, we shall be willing to consider the position further.
You will see a menu item entitled Submission Needing Revision.
Your submission record may be viewed there.
这是我的回复:
Dear Editor:We thank you very much for giving us an opportunity to revise our manuscript, we appreciate editor and reviewers very much for their positive and constructive comments and suggestions on our manuscript entitled “。。。。”. (ID: 。。。。).
We have studied reviewer’s comments carefully and have made revision which marked in red in the paper. We have tried our best to revise our manuscript according to the comments. Attached please find the revised version, which we would like to submit for your kind consideration.
We would like to express our great appreciation to you and reviewers for comments on our paper.
Looking forward to hearing from you.
Thank you and best regards.
这是录用的信件
Dear Mr. yangThank you for submitting a revised version of the above submission and your response to the comments made by the reviewers. I am pleased to confirm that the paper is accepted for publication in Materials Science and Technology. It was accepted on 29 Oct 2012You will shortly receive an email detailing log-in instructions for ManeyTrack - Maney Publishing's web-based production tracking system. Via ManeyTrack you will be able to view the production status of your article at any time, and also have the option to place orders for offprints, issue copies (if the journal has a print offering) and to make your article open access via Maney's MORE OpenChoice offering (see below).
Thank you for submitting your work to Materials Science and Technology.
看到Thank you for submitting a revised version of the above submission and your response to the comments made by the reviewers. I am pleased to confirm that the paper is accepted for publication in Materials Science and Technology. It was accepted on 29 Oct 2012这个,我和同学激动地拥抱了。
