主题:【已应助】求助几篇文献,谢谢哈
浏览0 回复5 电梯直达
lzzjd
悬赏金额:10积分 状态: 已解决
序号:1
标题:Dynamic vacuum stability test method and investigation on vacuum thermal decomposition of HMX and CL-20
作者:Rui Liu
期刊:Thermochimica Acta
网址:http://www.sciencedirect.com/science/article/pii/S0040603112000962
序号:2
标题:Initial chemical events in shocked octahydro-1,3,5,7-tetranitro-1,3,5,7- tetrazocine: A new initiation decomposition mechanism
作者:Weihua Zhu
期刊:JCP
网址:http://jcp.aip.org/resource/1/jcpsa6/v136/i4/p044516_s1?isAuthorized=no
序号:3
标题:First-principles studies on the thermal decomposition behavior of FOX-7
作者:Zhaoyang Zheng
期刊:High Pressure Research: An International Journal
网址:http://www.tandfonline.com/doi/abs/10.1080/08957959.2010.485390
序号:4
标题:Thermal decomposition behaviour of RDX by first-principles molecular dynamics simulation
作者:JC XU
期刊:Molecular Simulation
网址:http://www.tandfonline.com/doi/abs/10.1080/08927020802162892
序号:5
标题:The first principle studies of the structural and vibrational properties of solid β-HMX under compression
作者:LY Lu
网址:http://www.tandfonline.com/doi/abs/10.1080/00268970802616343
推荐答案:hstudent回复于2013/02/15
1 o k o k
hstudent
hstudent
hstudent
hstudent
hstudent
