分离模式 | 标题 | 色谱柱 |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-5ms | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-5MSi | Zebron™ ZB-5MSi, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-MR1 | Zebron™ ZB-MultiResidue™-1, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-MR2 | Zebron™ ZB-MultiResidue™-2, gc Cap. Column 30 m x 0.25 mm x 0.20 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-1701P | Zebron™ ZB-1701, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-35 | Zebron™ ZB-35, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-XLB | Zebron™ ZB-XLB, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Halogenated Pesticides Mix # 5 on ZB-50 | Zebron™ ZB-50, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Reversed Phase Chromatography | iMethod: Screening >350 Pesticides from Food & Feed According to Regulation (EC) No. 396/2005 | Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea |
Reversed Phase Chromatography | iMethod™ Food - Screening of 535 Pesticides by QuEchERS and $$lc/MS/MS | Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea |
