针对中华人民共和国出入境检验检疫行业标准《SN/T 3147-2012出口食品中邻苯二甲酸酯的测定》,我司现提供符合标准要求的23种邻苯二甲酸酯混标,结合标准中的定量限,同时为了提高检测灵敏度组分21、邻苯二甲酸二异壬酯(DINP)与组分22、邻苯二甲酸二异癸酯(DIDP)浓度调整为5000ug/ml。
详细信息如下:
Cat. No:46658
Total# of Analytes: 23
Solvent: n-Hexane
Volume: 1ml
序号 | 中文名称 | 英文名 | CAS | 浓度 |
1 | 邻苯二甲酸二甲酯(DMP) | dimethyl phthalate | CAS:131-11-3 | 1000ug/ml |
2 | 邻苯二甲酸二乙酯(DEP) | diethyl phthalate | CAS:84-66-2 | 1000ug/ml |
3 | 邻苯二甲酸二异丙酯(DIPrP) | Diisoprpyl phthalate | CAS:605-45-8 | 1000ug/ml |
4 | 邻苯二甲酸二烯丙酯(DAP) | Diallyl phthalate | CAS:131-17-9 | 1000ug/ml |
5 | 邻苯二甲酸二丙酯(DPrP) | Dipropyl phthalate | CAS:131-16-8 | 1000ug/ml |
6 | 邻苯二甲酸二异丁酯(DIBP) | diisobutyl phthalate | CAS:84-69-5 | 1000ug/ml |
7 | 邻苯二甲酸二丁酯(DBP) | dibuthyl phthalate | CAS:84-74-2 | 1000ug/ml |
8 | 邻苯二甲酸二(2-甲氧基乙基)酯(DMEP) | bis(2-methoxyethyl) phthalate | CAS:117-82-8 | 1000ug/ml |
9 | 邻苯二甲酸二异戊酯(DIPP) | diisopentyl phthalate | CAS:605-50-5 | 1000ug/ml |
10 | 邻苯二甲酸二(4-甲基-2-戊基)酯(BMPP) | bis(4-methyl-2-pentyl) phthalate | CAS:146-50-9 | 1000ug/ml |
11 | 邻苯二甲酸二(2-乙氧基)乙酯(DEEP) | bis(2-ethoxyethyl) phthalate | CAS:605-54-9 | 1000ug/ml |
12 | 邻苯二甲酸二戊酯(DPP) | dipentyl phthalate | CAS:131-18-0 | 1000ug/ml |
13 | 邻苯二甲酸二己酯(DHXP) | dihexyl phthalate | CAS:84-75-3 | 1000ug/ml |
14 | 邻苯二甲酸丁基苄基酯(BBP) | benzyl butyl phthalate | CAS:85-68-7 | 1000ug/ml |
15 | 邻苯二甲酸二(2-丁氧基)乙酯(DBEP) | bis(2-n-butoxyethyl) phthalate | CAS:117-83-9 | 1000ug/ml |
16 | 邻苯二甲酸二环己酯(DCHP) | dicyclohexyl phthalate | CAS:84-61-7 | 1000ug/ml |
17 | 邻苯二甲酸二(2-乙基己)酯(DEHP) | bis(2-ethylhexyl) phthalate | CAS:117-81-7 | 1000ug/ml |
18 | 邻苯二甲酸二正庚酯(DHP) | Di-n-Heptyl phthalate | CAS:3648-21-3 | 1000ug/ml |
19 | 邻苯二甲酸二苯酯(DPhP) | diphenyl phthalate | CAS:84-62-8 | 1000ug/ml |
20 | 邻苯二甲酸二正辛酯(DNOP) | di-n-octyl phthalate | CAS:117-84-0 | 1000ug/ml |
21 | 邻苯二甲酸二异壬酯(DINP) | diisononyl phthalate | CAS:68515-48-0 | 5000ug/ml |
22 | 邻苯二甲酸二异癸酯(DIDP) | Diisodecyl phthalate | CAS:26761-40-0 | 5000ug/ml |
23 | 邻苯二甲酸二壬酯(DNP) | dinonyl phthalate | CAS:84-76-4 | 1000ug/ml |
食品中邻苯二甲酸酯检测前处理及相关色谱产品
产品名称 | 规格及包装量 | 货号 |
样品前处理 | ||
AOAC萃取试剂盒(含萃取盐包及50mL离心管) | 50/pk | 64520 |
AOAC净化试剂盒 50 mg PSA / 50 mg C18 / 150 mg MgSO4 | 2mL,100/pk | 64505 |
ProElut PSA Glass SPE小柱 | 1 g/6 mL,30/pk | 63206G |
12管防交叉污染真空SPE萃取装置 | 12位 | 244358 |
考克(控制流量) | 15/pk | 4806 |
通用连接器 | 15/pk | 4803 |
无油真空正压两用泵 | 1/pk | 99011 |
色谱柱 | ||
DM-5MS 60 m×0.25 mm×0.25 μm | 1/pk | 8222 |
HPLC溶剂 | ||
甲醇 HPLC级 | 4L | 50102 |
乙腈 HPLC级 | 4L | 50101 |
甲基叔丁基醚 HPLC级 | 4L | 50123 |
正己烷 HPLC级 | 4L | 50115 |
通用色谱产品 | ||
样品瓶,棕色螺纹,带书写刻度 | 2mL,100/pk | 5323 |
瓶盖(含垫) | 100/pk | 5325 |
