Abstract
Decomposition in soil of the herbicide diflufenican, N-(2,4-difluorophenyl)-2-[3-(trifluorome-thyl)phenoxy]-3-pyridinecarboxamide, was studied after application for weed control on Swedish railway embankments. A new sensitive method has been developed for determination of aged residues of diflufenican in soil by gc-ECD. A sample extraction using 100% methanol with “extended shake” was performed. The extract was concentrated and purified on a C18-SPE coiumn. Further clean-up was made by using a Silica SPE column. Minimum level of detection for diflufenican was 0.001 μg g−1 soil. Recovery of diflufenican over the range 0.02 μg g−1 to 0.2 μg g−1soil by this method was generally between 94.3% and 121.2% (15 out of 15 determinations). The amounts of diflufenican found in the soil samples at various times after their application were mainly between 0.2 μg g−1 and level of detection.
看这个介绍,感觉您可以试试日本官方发布的LCMSII法做除草剂,它也用到硅胶柱。
原文由 雾非雾(mcds) 发表:
Gas-Chromatographic Methods for Determination of Diflufenican in Soil
Abstract
原文由 雾非雾(mcds) 发表:
Abstract
