主题:【分享】龙海益德工贸有限公司输日荔枝检测出对氯苯氧乙酸(4-CPA)超标(18楼)
浏览0 回复20 电梯直达
雾非雾
漳州市德兴贸易有限公司输日荔枝检测出对氯苯氧乙酸(4-CPA)超标。
厚生労働省は、輸入時のモニタリング検査の結果、中国産生鮮レイシ(ライチ)から基準値を超える4-クロルフェノキシ酢酸が検出されたと発表した。
この結果を受け、中国産レイシ(ライチ)及びその加工品(簡易な加工に限る)の残留農薬に係るモニタリング検査の頻度を30%に引き上げて対応すると通知した。(平成25年6月6日)
◆4-クロルフェノキシ酢酸(对氯苯氧乙酸)
用途:成長調整剤
基準値:0.02ppm
福建省漳州市德兴贸易有限公司(ZHANGZHOU DEXING TRADING CO.,LTD.)
附件:
该帖子作者被版主 MMYG2积分, 2经验,加分理由:分享
MMYG
ljb1978
雾非雾
原文由 ljb1978(ljb1978) 发表:
怎么都是日本检测超标的?难道出口没有检测
因为我在的单位主要是对日本出口蔬菜。
雾非雾
Gas Liquid Chromatographic Determination of 4 Chlorophenoxyacetic Acid Residues in Mung Bean Sprouts
Gas-liquid chromatographic determination of 4-chlorophenoxyacetic acid residues in mung bean sprouts.
J Assoc Off Anal Chem 1982 Sep;65(5):1118-21
Wong YS.
A gas-liquid chromatographic (GLC) method is described for determining 4-chlorophenoxyacetic acid (CPA) residues in mung bean sprouts. The residues were extracted from samples by using ethyl acetate followed by liquid-liquid partition into 5% NaHCO3 solution. After acidification and reextraction with ethyl acetate, CPA was reacted with pentafluorobenzyl bromide (PFB-Br) to form the PFB derivative. The reaction mixture was separated on a silica gel column to remove excess reagent, and the derivative was eluted with a solution of 75% toluene in hexane. GLC separations were performed on a 3% OV-1 column at 230 degrees C. As low as 10 pg CPA could be quantitated, which is equivalent to about 0.05 ppm at residue level, using an electron capture detector. Recoveries of CPA from fortified mung bean sprouts (0.05, 0.20, and 0.50 ppm) ranged from 71 to 107%. The PFB derivative was further identified by gas chromatography-mass spectrometry.
雾非雾
Degradation of chlorophenoxyacetic acids by the lignin-degrading fungus Dichornitus squalens
文中提到4-CPA的代谢物的检测。
附件:
雾非雾
色谱柱:Kinetex™ 2.6 µm PFP 100 Å, $$lc Column 50 x 2.1 mm, Ea
尺寸:50 x 2.1 mm ID
洗脱类型:Isocratic
洗脱A:0.1% Formic acid in Water
洗脱B:0.1% Formic acid in Acetonitrile
梯度:
步骤顺序
时间 (分)
流动相A
流动相B
1
4
70
30
流速:0.8 mL/min
冷却温度:25 °C
检测:UV-Vis Abs.-Variable Wave.(UV) @ 280 nm (25°C)
备注:SecurityGuard™ ULTRA Guard Cartridge System extends column lifetime.
- SecurityGuard ULTRA Cartridges, UHP$$lc PFP for 2.1mm ID Columns, 3/Pk Part No.: AJ0-8787
- Holder Part No.: AJ0-9000
色谱柱:Luna® 3 µm PFP(2) 100 Å, $$lc Column 150 x 4.6 mm, Ea
尺寸:150 x 4.6 mm ID
洗脱类型:Gradient
梯度:
步骤顺序
时间 (分)
流动相A
流动相B
1
45
55
2
6
25
75
流速:1 mL/min
冷却温度:室温
检测:UV-Vis Abs.-Variable Wave.(UV) @ 280 nm (22°C)
备注:SecurityGuard™ Guard Cartridge System extends column lifetime.
- SecurityGuard Cartridges, PFP 4 x 3.0 mm, 10/Pk Part No.: AJ0-8327
- Holder Part No.: KJ0-4282
雾非雾
高效液相色谱-串联质谱法测定芽苗类蔬菜及其来源豆类中4种非法添加物的残留量
绿豆芽,对氯苯氧乙酸、6-苄基腺嘌呤、恩诺沙星和诺氟沙星
附件:
zjf1975
pingguwu
雾非雾
原文由 pingguwu(pingguwu) 发表:
我们也在检测,就是没有去做荔枝。
是用的单独法做的?
