X荧光光谱仪部分常用备件 | |
名称 | 订货号 |
Teeth Belt (Spinner) | 5322 358 31208 |
Teeth Belt (Turret) | 5322 358 31207 |
Photo Interruptor | 5322 693 11078 |
O-Ring Viton 2.62x69.52 (50× Shore) | 5322 530 50613 |
O-ring RUBB 58.42x2.62 | 5322 530 51298 |
Blade Spring | 5322 492 71289 |
Back up Ring | 5322 530 50713 |
Quad Ring | 5322 530 50708 |
Pneumatic Actuator CP95SDB32-100 | 5322 790 00501 |
Pneumatic Actuator RM8026/50 | 5322 360 40503 |
Coupling | 5322 739 00021 |
1Q DC Motor | 5322 361 21563 |
2Q DC Motor | 5322 694 15221 |
Spinner Motor | 5322 785 01501 |
Turret Motor, Maxom with tacho | 5322 694 15554 |
Quad Ring Minn 4009 | 5322 532 52395 |
Backup Ring For Quad Ring 4009 | 5322 530 50874 |
Flanged seal | 5322 535 71317 |
Quad ring Minn 4009 | 5322 532 52395 |
Backup ring for Quad ring Minn 4009 | 5322 530 50874 |
Vacuum Pump Edwards Type RV8 | 5322 360 20126 |
Vacuum Pump Edwards Type RV3 | 5322 360 20125 |
Fluor Rubber Hose 6.6x3.4x500 | 5322 530 20516 |
Detector cable hose clip (Flow detector) | 5322 492 71593 |
Detector cable hose clip (Scint. detector) | 5322 492 63371 |
Set of 5 Windows: | |
2 Micron | PW2417/02 |
1 Micron | PW2417/01 |
Tube light TL 13W | 5322 694 15543 |
Fan | 5322 785 03301 |
Fan | 5322 361 10985 |
Fan and Wiring | 5322 694 15541 |
Lamp 12V 3W | 5322 134 80205 |
Tin Al oxide pellets | 5322 390 84003 |
Apiezion M. 25g Tube | 5322 390 20145 |
HT-Silicon Grease | 5322 390 20011 |
Vacuum Oil Ultragrade 19 | 5322 390 10098 |
Filter Water | 5322 480 54034 |
C3 Test Sample | 5322 397 10133 |
Water flow meter 0.2-6 l/min | 5322 349 20147 |
PROCON water pump | 5322 784 00011 |
Detector gas control board | 5322 694 15235 |
CPU2000 board | 5322 790 00921 |
Spectrometer T2 control board (SPECTRT-CNTR) | 5322 790 00911 |
Spectrometer M control board (SPECTRO-M-CONTROL) | 5322 785 01511 |
Spinner changer interface board (SCI) | 5322 790 00941 |
Position control board (POSCON2) | 5322 694 16023 |
Dual multi-channel analyzer board (DMCA) | 5322 790 00931 |
Low voltage power supply LPQ172 | 5322 785 01461 |
Low voltage power supply LPS255-C | 5323 785 00101 |
原文由 panake(panake) 发表:
X荧光光谱仪部分常用备件 名称 订货号 Teeth Belt (Spinner) 5322 358 31208 Teeth Belt (Turret) 5322 358 31207 Photo Interruptor 5322 693 11078 O-Ring Viton 2.62x69.52 (50× Shore) 5322 530 50613 O-ring RUBB 58.42x2.62 5322 530 51298 Blade Spring 5322 492 71289 Back up Ring 5322 530 50713 Quad Ring 5322 530 50708 Pneumatic Actuator CP95SDB32-100 5322 790 00501 Pneumatic Actuator RM8026/50 5322 360 40503 Coupling 5322 739 00021 1Q DC Motor 5322 361 21563 2Q DC Motor 5322 694 15221 Spinner Motor 5322 785 01501 Turret Motor, Maxom with tacho 5322 694 15554 Quad Ring Minn 4009 5322 532 52395 Backup Ring For Quad Ring 4009 5322 530 50874 Flanged seal 5322 535 71317 Quad ring Minn 4009 5322 532 52395 Backup ring for Quad ring Minn 4009 5322 530 50874 Vacuum Pump Edwards Type RV8 5322 360 20126 Vacuum Pump Edwards Type RV3 5322 360 20125 Fluor Rubber Hose 6.6x3.4x500 5322 530 20516 Detector cable hose clip (Flow detector) 5322 492 71593 Detector cable hose clip (Scint. detector) 5322 492 63371 Set of 5 Windows: 2 Micron PW2417/02 1 Micron PW2417/01 Tube light TL 13W 5322 694 15543 Fan 5322 785 03301 Fan 5322 361 10985 Fan and Wiring 5322 694 15541 Lamp 12V 3W 5322 134 80205 Tin Al oxide pellets 5322 390 84003 Apiezion M. 25g Tube 5322 390 20145 HT-Silicon Grease 5322 390 20011 Vacuum Oil Ultragrade 19 5322 390 10098 Filter Water 5322 480 54034 C3 Test Sample 5322 397 10133 Water flow meter 0.2-6 l/min 5322 349 20147 PROCON water pump 5322 784 00011 Detector gas control board 5322 694 15235 CPU2000 board 5322 790 00921 Spectrometer T2 control board (SPECTRT-CNTR) 5322 790 00911 Spectrometer M control board (SPECTRO-M-CONTROL) 5322 785 01511 Spinner changer interface board (SCI) 5322 790 00941 Position control board (POSCON2) 5322 694 16023 Dual multi-channel analyzer board (DMCA) 5322 790 00931 Low voltage power supply LPQ172 5322 785 01461 Low voltage power supply LPS255-C 5323 785 00101
