常用分析元素±0.03nm范围干扰內受常見元素的干扰情況
波長 (nm) | 強 度 | 波長 (nm) | 強 度 | ||
電弧 | 火花 | 電弧 | 火花 | ||
Ag Ce Ⅱ 328.049 15 1 Rh Ⅰ 328.055 30R 10 Eu 328.068 1000R —— Ag Ⅰ 328.068 2000R 1000R Cu 328.069 10 2 Mn 328.088 60 30 Sm 328.084 20 6 Mo 328.088 —— 25 Y Ⅱ 328.091 8 12 Al V Ⅰ 394.366 50 18 Nb 394.367 20 50 Th 394.369 10 10 U 394.382 35 5 Ce Ⅱ 394389 40 15 Al Ⅰ 394.401 2000 1000
| As Pt Ⅱ 188.952 50 50 Ag Ⅲ 188.957 —— 30 Au 188.98 As 189.042 500 —— Si Ⅰ 189.272 Tt Ⅱ 189.28 B Fe 249.653 40 15 Ta 249.664 20 —— W Ⅱ 249.664 10 100 Pd Ⅱ 249.669 — 100 Sn 249.667 10 —— B 249.678 200 200 Hf Ⅱ 249.699 30 40 Fe 249.699 20 1 Se Se 196.026 Se Ⅰ 196.51 |
Be V Ⅱ 313.027 50 200r Fe 313.028 5 4 Ce Ⅱ 313.033 30 1 Be Ⅱ 313.042 200 200 W 313.046 8 Si 313.048 - 5 U 313.056 - 15 Cr 313.057 1 12 Ta 313.058 100w 35 Nb 313.079 100 100 Bi Nb 306.753 - 15 W Ⅱ 306.757 3 12 Mo 306.764 10 50 Sm 306.767 15 15 Bi Ⅰ 306.773 3000hR 2000wh Th 306.773 12 20 Sn 306.776 10 15 U 306.776 8 6 | Cd W 214406 10 10 As Ⅰ 214.410 50r - Pt Ⅰ、Ⅱ 214.423 35 100 Cd Ⅱ 214.4338 50 200R Fe 214.445. 25 - W 214.450 8 10 Ce Zr Ⅱ 399.897 30 30 U 399.918 10 3h Pr 399.919 50d 40d V Ⅰ 399.919 - 40h Ce Ⅱ 399.924 80 20 Co La Ⅱ 345.317 50 40 Cr Ⅱ 345.333 35 35 Co Ⅰ 345.350 3000R 200 Ti 345.353 5h - U 345.357 5 8 Tm 345.366 150 80 Cr 345.374 30 25 |
Be V Ⅱ 313.027 50 200r Fe 313.028 5 4 Ce Ⅱ 313.033 30 1 Be Ⅱ 313.042 200 200 W 313.046 8 Si 313.048 - 5 U 313.056 - 15 Cr 313.057 1 12 Ta 313.058 100w 35 Nb 313.079 100 100 Bi Nb 306.753 - 15 W Ⅱ 306.757 3 12 Mo 306.764 10 50 Sm 306.767 15 15 Bi Ⅰ 306.773 3000hR 2000wh Th 306.773 12 20 Sn 306.776 10 15 U 306.776 8 6 | Cr Bi Ⅰ 425.415 10 10 Cr Ⅰ 425.435 5000R 1000R Nb 425.439 10 15 Pr 425.442 35 18 Mo 425.442 10 5 Ho 425.443 100 20 Mn Zr Ⅰ 257.611 8 - W 257.617 2 20 W Ⅱ 257.636 2 15 Pd Ⅱ 257.640 - 100 Ni Pd Ⅱ 231.587 2 25 U 231.588 —— 10 Sb 231.588 20 9 Re 231.604 30 10 Tl Ⅰ 231.598 60R —— Ni Ⅱ 231.604 15 25w Co 231.616 10w —— | ||||
Pb Mo 405.758 10 4 Ti Ⅰ 405.762 40 6 Mg Ⅰ 405.763 10w —— Zn Ⅱ 405.771 80 —— Pb Ⅰ 405.782 2000R 300R Er 40.5782 30 —— V Ⅰ 4053.783 10 2 In 405.787 80 10 Mn 405.795 80 20 Zr Ce Ⅱ 349.594 15 1 Ti Ⅰ 349.596 10 —— Co 349.607 10 —— Zr Ⅱ 349.621 100 100 Ni Ⅰ 349.635 15 - Hf Ⅱ 349.593 10 10 U 349.642 8 15 Y Ⅱ 349.608 20 35 | Cu Cr Ⅰ 324.727 20 1 Fe Ⅰ 324.728 20 10 Nb 324.747 50w 100w Cu Ⅰ 324.757 500R 2000R Mn 324.754 125 - Ag 324.755 15 15 Ce 324.755 15 - La Ar Ⅰ 433..356 - 〖1000〗 La Ⅱ 433.373 500 500 Pr 433.391 150 100 V Ⅰ 433.409 20 12 Sm Ⅱ 433.415 200 200 Mn W 257.590 9 1 Nb 257.596 1 10 Ru 257.610 - 50 Mn Ⅱ 257.610 300R 2000R |
Mg Fe Ⅰ 285.180 200 150 Zr Ⅱ 285.197 12 20 Hf Ⅱ 285.201 20 50 W 285.210 1d 180h Ce 285.212 50d 1 Mg Ⅰ 285.213 300R 100R Fe 285.213 150 80 Ir 285.213 20 - Mo 285.213 10h 10 Ta 285.236 5 100 Mn Th 403.426 10 10 Pr 403.430 20 5 Gd 403.438 5 - Mn Ⅰ 403.449 250r 20 Nb 403.452 10 5 Tm 403.474 10 10 | Mn
Ta 263.793 1 10h Yb 263.809 1 60 Nb 263.813 - 20h Mn 263.817 25 80h W 263.822 - 10 Fe 263.824 - 2 Al Ⅱ 263.826 - 〖30〗 Mo 263.830 25 5 Sb W 259.795 —— 12 Re 259.796 20 —— Nb 259.804 2 10 Sb Ⅰ 259.806 200 100 Mn 259.817 12 —— Ta 259.821 2s 50 Fe Ⅲ 259.837 700 1000h |
Si Mo 288.137 —— 10 Al Ⅲ 288.146 —— 〖30〗 Gd 288.158 40 —— Ce 288.158 40 2 Si Ⅰ 288.158 500 400 Co 288.158 4 1 Ca 288.180 —— 4 Cr 288.193 1 30 Sn Ti Ⅱ 317.480 - 100 Co Ⅰ 317.491 80 —— Fe 317.496 5 4 Sn 317.502 500h 400hr Mo 317.505 2 60 Na Ⅱ 317.509 —— 〖15〗 Te Ⅰ 317.511 30 {15} Ru 317.515 20 100 | Ti Tb 337.272 50 —— Nb 337.275 55 20 Y 337.277 15 3 Pr 337.280 10 4 Ti Ⅱ 337.280 80 400R Fe 337.286 2 - Mo 337.292 5 1 Pd Ⅰ 337.300 800r 500wh Mo 337.313 5 25 Zn Zr Ⅱ 334.479 15 15 W Ⅱ 334.490 3 12 Zn Ⅰ 334.502 800 300 Nd 334.509 12 2 W 334.509 9 8 Cr 334.515 15 2 |
Ni Zr Ⅱ 341.466 20 15 Co Ⅱ 341.477 200w —— Ni Ⅰ 341.477 1000R 50wh Te Te Ⅰ 214.275 600 _ La 214.281 2h 1hl V Ⅱ 214.305 10 50 Fe Th 373.460 8 10 Yb 373.470 25 5 Ce Ⅰ 373.487 60 _ Fe Ⅰ 373.487 1000r 600 Re Ⅰ 373.500 30w _ V 373.517 3 25 | bh : 分子带头 d : 双线 h :扩散线 L :向长波扩散的对称线 r ;锐自蚀线 R : 宽自蚀线 s : 向短波扩散的非对称线 W : p宽线在、或具有精细结构的线 〖〗 ; 表示在宽线放电管内的强度 Ⅰ Ⅱ Ⅲ :中性原子〖Ⅰ〗一次电离离 子〖 Ⅱ 〗 ,一次电离离子〖 Ⅲ 〗 ,… 发射的谱线 〖〗 : 表示在放电管内的强度 |
C Ni Ⅲ 193.043 Co Ⅲ 193.048 In Ⅱ 193.052 C Ⅰ 193.091 150 —— Cu Pb 224.689 30R 100R Ir 224.690 10 100 Fe Ⅲ 224.691 —— 20 Mo 224.695 —— 20 Cu Ⅱ 224.700 30 500 Mo 224.711 —— 15 Ni Ⅲ 224.723 2 12 Cu Cr 324.727 20 1 Nb 324.747 50w 100w Cu Ⅰ324.754 5000R 2000R Mn 324.757 125 —— Ag 324.755 15 15 Ce 327.762 15 —— Mo 327.762 30 20 | Mn Fe Ⅰ 293.908 80 20 W 293.918 8 2 Ir Ⅰ 293.927 20 15 Ta 293.928 200 40h Mn 293.930 50 _ Cr 293.945 6 20 Fe Ⅱ 293.951 3 30 Mo W 202.013 8 2h Os 202.026 25 10 Mo 202.030 20 50r Fe 202.052 2 100 Sb Ar Ⅱ 217.925 _ 〖40〗 Sb 217.926 35 40 Ni Ⅱ 217.935 2 10
Cu Ⅱ 217.940 12 35 Ta 217.954 6 201 | ||||
Mg Fe Ⅱ 279.056 _ 35 Ti Ⅱ 279.066 _ 30wh U 279.067 8 10 Ta 279.071 150 10 Mg Ⅱ 279.079 40 80 Co Ⅰ 279.101 50 _ Nb Ti Ⅱ 319.467 _ 40wh Ce 319.483 25 _ Ta 319.484 1h 40 Nb Ⅱ 319.498 30 300 Mo 319.524 1 20 Si Mo 212.410 6 20 V 212.411 6 5 Ni 212.411 30 _ Si Ⅰ 212.415 200R 50 Nb 212.434 2 8 Os 212.439 25 5 | Si Er 390 542 18 1 Ir Ⅰ 390.545 8 _ Si Ⅰ 390.553 20 15w Cr 390.566 2 4 Ho 390.578 30 6 V Ti Ⅱ 311.062 8 18 Ti 311.067 10 100 Mn 311.068 35 35 V Ⅱ 311.071 70 300R Co Ⅰ 311.083 60 2 Fe 311.084 20 10 Mo 311.084 _ 30 Cr 311.086 25 8 Zr Ⅱ 311.088 10 8 W Ag Ⅱ 220.440 _ 10h W Ⅱ 220.448 12 30 V 220.450 _ 40 Al 220.463 10R 10 |
