原文由 xfuzengh(xfuzengh) 发表:
我们也有参加,关于以下要求如何理解,是要求直接将两个整块按送样状态测试而不是按标准切碎为不大于6mm*6mm吗:
Important information
1) Ensure the entire piece of material supplied is taken for analysis.
2) Calculations for analysis are to be on a sample mass of 0.1g.
3) When performing the final calculations 0.1g must be used as the mass of material taken.
4) DO NOT perform any calculations based upon the actual weight of material supplied..
