主题:彻底揭密ARL软件(1)
浏览0 回复6 电梯直达
happy_cheng
一个分析软件往往有很多文件组成,包括了很多怪怪的扩展名,下面我给你讲解一下ARL分析软件的众多扩展名的文件类型,看不懂英文的提问我负责讲解哦!!
扩展名------  类型 -------------------------------------详细解释
ASC--Analytical task:Auto control---------All data  related to control sample for automation Mode
ALY--Alloy sort File ------------------- All data related to an alloy used for Quality sotr
APS--Analytical Task:Auto prod -------- All data related to Production Samples for Automation Mode
ASS--Standardistion:Auto standardisation--All data related to setting-up Samples forAutomation Mode
ATS--Type standard:Auto type standard----All data related to type Standards for Automation Mode
BCH--Batch context File -----------------Analytical task to be run in sequence
CAL--Calibration Task------------------- Analytical task used to measure the calibration standards
CHO--Program choice --------------------All data related to program choice
CIS--calibration attribute import-------All data related calibration standard import
CTL--Analytical task:control sample-----Analytical task used to measure the control samples
CXS--calibration attribute export-------All data related calibration standard export
(continue)
DAT--Ddtabase---------------Instsrument alarms and modification reasons.
DIN--Standardisation Initialisation Task--- Analytical Task used to initialise the setting-up Samples.
DMP--I/O Tracing File-------- Recorded data of communication lines.
DUP--Standardistion update Task--Analytical Task used to update the setting-up Samples.
EMU--ICS Dialogue Save State File----Simulated analytical results used for lff-line measurement.
HED--Database-----------------Instrument alarms and modification reasons
IPR--Integrated Profile------------------- All data related to profile by integrations
LDH--Laser Drift File--------------------All data related to Laser Drift History
MCF--calibration Transfer File-------Data related to calibration standards
(continue)
happy_cheng
renzhihai
seavoh
happy_cheng
东方电源
