6.5 Polarization Modulation Vibrational Linear Dichroism (PM-VLD)
6.5.1 Introduction
The absorption of infrared radiation by an oriented sample is sensitive to the state of polarization of the incident radiation with respect to a reference direction. The reference direction can be defined by the stretching direction of a polymer, the director of a liquid crystal or a monolayer film, the polarization direction of a laser in photo-induced orientation studies, or more generally, by the direction of the external constraint that produces the anisotropy in the sample. The anisotropic optical absorption of oriented samples, so-called dichroism, can be analyzed by measuring spectra using light polarized parallel and perpendicular to the fixed reference direction. This type of experiment is called infrared linear dichroism (IRLD), or in a more general sense, vibrational linear dichroism (VLD). The dichroism ratio Rd and dichroic difference ΔA are the common parameters that are used to characterize the degree of optical anisotropy in oriented samples and they are defined by Equations (6-8) and (6-9) respectively:
