裂解和
气相色谱联用的方法在高聚物研究,高聚物添加剂测试中的应用非常广泛,但作为标准方法应用却不是很多,下面是一些应用裂解
气相色谱联用的方法测试高聚物和添加剂的标准方法。
高聚物分析的主要集中在橡胶,而添加剂测试的方法也只是最近才有,比如ASTM D7823-13测定PVC中的邻苯二甲酸酯类物质,IEC 62321中也是推荐裂解作为筛选方法来测定聚合物中的邻苯二甲酸酯类物质。
裂解要作为常规的聚合物添加剂或限制物质测试的方法,需要解决的主要问题:
1.样品均匀性问题
2.系统抗污染
3.检出限
部分现有标准方法如下:
1. 橡胶和橡胶制品用热裂解法测定硫化和未硫化化合物的成分第1部分:丁二烯、乙烯-丙烯共聚物和三聚物、异丁烯-异戊二烯、异戊二烯和丁二烯橡胶
Rubber and rubber products – Determination of the composition of vulcanizates and uncured compounds by thermogravimetry – Part 1: Butadiene, ethylene-propylene copolymer and terpolymer, isobutene-isoprene, isoprene and styrene-butadiene rubbers
【标准号】:ISO 9924-1-2000
2. 橡胶和橡胶制品用热裂解法测定硫化和未硫化化合物的成分第2部分:丙烯腈丁二烯和丁基卤化橡胶
Rubber and rubber products – Determination of the composition of vulcanizates and uncured compounds by thermogravimetry – Part 2: Acrylonitrile-butadiene and halobutyl rubbers
【标准号】:ISO 9924-2-2000
3. 橡胶 裂解
气相色谱分析法第1部分:聚合物(单一及并用)的鉴定
Rubber.Analysis by pyrolytic gas-chromatographic methods.Part 1:Identification of polymers (single polymers and polymer blends)
【标准号】:GB/T 29613.1-2013
4. 裂解
气相色谱法鉴定聚合物
Identification of polymers by pyrolytic gas chromatography
【标准号】:GB/T 7131-1986
5. 橡胶的标准实施规程.裂解
气相色谱法识别
Standard Practice for Rubber8212;Identification by Pyrolysis-Gas Chromatography
标准号:ASTM D3452-2006
6. 橡胶.裂解
气相色谱法.第1部分:聚合物(单一聚合物和聚合物混合物)的鉴定 (Rubber.Analysis by pyrolytic gas-chromatographic methods.Part 1:Identification of polymers(single polymers and polymer blends))
标准号:SH/T 1764.1-2008
7. Determination of Low Level, Regulated Phthalates in Poly (Vinyl Chloride) Plastics by Thermal Desorption—Gas Chromatography/Mass Chromatography
ASTM D7823-13
8. Determination of certain substances in electrotechnical products -
Part 8: Phthalates in polymers by Pyrolyzer Gas Chromatography-Mass Spectrometry (Py-GC-MS), Ion Attachment Mass Spectrometry (IAMS), Gas Chromatography-Mass Spectrometry (GC-MS) and Liquid Chromatography – Mass Spectrometry (
LC-MS)
IEC 62321 2nd Edition
9. Standard Practice for Qualitative Identification of Polymers in Emulsion Paints
ASTM D3168
10. 橡胶.热解
气相色谱分析法.第2部分:苯乙烯/丁二烯/异戊二烯比率的测定
Rubber – Analysis by pyrolytic gas-chromatographic methods – Part 2: determination of styrene/butadiene/isoprene ratio
NF T46-051-2-2012
