主题:【求助】求助:xps测试c1s出现了三个峰,该怎么分析
浏览0 回复6 电梯直达
丶Harry
c1s样品应该只有c1s只有一个峰,可是貌似至少得三个峰,哪位大神能不能帮忙分析一下啊
附件:
您可能想找: X光电子能谱仪(XPS/ESCA) 询底价
高德英特
XPS is a surface analysis technique which detect what presents on the top 10nm of the surface. In this case, samples are easily being oxidized or contaminated in different ways. In your C1s, while the biggest peak which fall around 285eV seems to be a C-C/C-H peak and then indeed there look to be another 2 peaks to the left. They can be C-O, C=O compound or even C-N...etc depending on within your full survey spectrum (full Binding Energy range scan) as what other elements are presented. For example, if O is presented, it could be CO some kinds of bonding compound is/are presenting.
Ins_57f31327
我的也出现这种情况,不知道楼主的联系方式是什么,想请教下啊
Insm_6faac6a4
三个峰应该是表明C存在三种化学形式,比如碳单键或者碳双建等等或者C-F键等等与其他不同元素成键,有三种不同配位方式,所以有三种不同峰
Insm_6faac6a4
原文由 Insm_6faac6a4(Insm_6faac6a4) 发表:
一般是以284.8ev作为荷电较正,也就是你图中最强峰
v3057677
Insm_6faac6a4
除了纯C材料,一般无机物都会吸附污染C 谱图中都会出现这三个峰 C-C C-O C=O
