主题:【已应助】请问安捷伦的FPD和FPD plus有什么区别?
浏览0 回复21 电梯直达
symmacros
symmacros
查到:
Flame Photometric Detector Plus (FPD Plus)
Agilent’s new Flame Photometric Detector Plus (FPD Plus) utilizes new photomultipliers, proprietary deactivation treatments and other design enhancements to help its lower MDL's when used in sulfur or phosphorous modes.  Design enhancements also resulted in raising the FPD Plus' maximum operating temperature.  These capabilities are also available with the dual-wavelenth version, the Agilent Dual Flame Photometric  Plus Detector Plus (DFPD Plus).
  • FPD Plus MDL (sulfur mode) is improved to 2.5 pg S/sec
  • FPD Plus MDL (phosphorous mode) is improved to 45 fg P/sec.
  • FPD Plus maximum operating temperature to 400°C.
  • These specifications are the same for its dual-wavelenth version, the Agilent Dual Flame Photometric Plus Detector (DFPD Plus).
  • 赞贴
    2016/2/25 21:51:09 Last edit by jimzhu
    wazcq
    安平
    安平
    sj123and123
    原文由 symmacros(jimzhu)发表:查到:
  • 学习了。
    symmacros
    原文由 wazcq(wazcq) 发表:
    自问自答啊,这个磷模式 45fg 比NPD还灵敏吧
    是开始不知道,后来查到上面的信息。请问NPD的P的灵敏度是多少?
    wazcq
    原文由 symmacros(jimzhu) 发表:
    5×10-13g/s(P)
    symmacros
    qqqid
    原文由 安平(byron1111) 发表:
    检出限和最高耐温都改进了
    最高耐温终于改进了,原来的FPD最高250度,做有机磷时柱温会达到280度,对FPD很不好。
    这曾经是安家气相的短板,其它几家进口品牌气相,FPD耐温一直很高,不存在这种问题。
    安平
  • 就是双波长,还是双火焰没看明白。
