测试方法 | 肥皂(g/L) | 无水碳酸钠(g/L) | 温度℃ | 时间 | 不锈钢球数目 | 液量(浴比) | |
GB3921/BS1006/ISO105 | DIN | ||||||
C01 | 54014 | 5 | ----- | 42±2 | 30分 | ------ | 50:1 |
C02 | 54013 | 5 | ----- | 50±2 | 45分 | ------ | 50:1 |
C03 | 54010 | 5 | 2 | 60±2 | 30分 | ------ | 50:1 |
C04 | 54011 | 5 | 2 | 95±2 | 30分 | 10 | 50:1 |
C05 | 54012 | 5 | 2 | 95±2 | 4小时 | 10 | 50:1 |
测试方法 | 温度℃ | 洗液量(ml) | 实验含氯量(%) | 过硼酸钠(g/l) | 时间(分) | ECE洗衣粉 | 钢球数 | PH |
AIS | 40 | 150 | None | None | 30 | 4g/l | 101) | |
A1M | 40 | 150 | None | None | 45 | 4g/l | 10 | |
A2S | 40 | 150 | None | 1 | 30 | 4g/l | 101) | |
B1S | 50 | 150 | None | None | 30 | 4g/l | 251) | |
B1M | 50 | 150 | None | None | 45 | 4g/l | 50 | |
B2 S | 50 | 150 | None | 1 | 30 | 4g/l | 251) | |
C1S | 60 | 50 | None | None | 30 | 4g/l | 25 | 10.5±0.1 |
C1M | 60 | 50 | None | None | 45 | 4g/l | 50 | 10.5±0.1 |
C2S | 60 | 50 | None | 1 | 30 | 4g/l | 25 | 10.5±0.1 |
D1S | 70 | 50 | None | None | 30 | 4g/l | 25 | 10.5±0.1 |
D1M | 70 | 50 | None | None | 45 | 4g/l | 100 | 10.5±0.1 |
D2S | 70 | 50 | None | 1 | 30 | 4g/l | 25 | 10.5±0.1 |
D3S | 70 | 50 | 0.015 | None | 30 | 4g/l | 25 | 10.5±0.1 |
D3M | 70 | 50 | 0.015 | None | 45 | 4g/l | 100 | 10.5±0.1 |
E1S | 95 | 50 | None | None | 30 | 4g/l | 25 | 10.5±0.1 |
E2S | 95 | 50 | None | 1 | 30 | 4g/l | 25 | 10.5±0.1 |
For delicate fabrics and articles of wool or silk or blends containing these fibres,steel balls are not used the test,Record the use of steel balls in the test report ﹝see>g﹞ |
测试方法 | 测试液 | 钢珠粒 | 温度℃ | 时间min | ||
皂粉g/l | 过硼酸钠g/l | 溶液体积ml | ||||
A-1 | 5 | - | 100 | - | 40±2 | 30 |
A-2 | 50±2 | |||||
A-3 | 2 | 60±2 | ||||
A-4 | 10 | 70±2 | 45 | |||
A-5 | 80±2 | |||||
A-6 | 95±2 | 30 | ||||
A-7 | 240 |
