根据Gilson的SPE资料介绍推荐二次洗脱,多次洗脱比一次效果更好,原文是“A second elution step is recommended. “Rule of thumb”two elution steps are more efficient than just one step using the entire volume.”
原文由 xyzwz123 发表: 根据Gilson的SPE资料介绍推荐二次洗脱,多次洗脱比一次效果更好,原文是“A second elution step is recommended. “Rule of thumb”two elution steps are more efficient than just one step using the entire volume.”
