Facts About Column Engineering
Although there are many distributors of columns and packing materials for HPLC, few bond their own packings and fewer still actually manufacture a silica bead from starting raw materials. The truth is that most column suppliers will not admit this or will make you believe that they are making their own materials. Making and bonding base material gives complete control of quality and consistent performance characteristics. Since 1981 column Engineering has been a supplier of packing materials to several prominent columns manufacturers. Now column Engineering is making these packings directly available to you in our Monitor and Reliasil lines.Whether you need bulk packings in various particle sizes and porosity, narrow pore or microbore, analytical, preparative, or custom columns, we can assist you. Our mission is to supply the most consistent, highest quality, and widest range of chromatography packing materials and columns in the industry. We maintain high standards by carrying the highest quality bulk packings available worldwide and by being one of only a few suppliers that actually manufactures our own silicas under strict controls and specifications. This assures our customers a consistent and readily available supply of products that you can count on for developing or transferring chromatography methods.Column Engineering is also proud to pack and distribute packings such as; Nucleosil, Hypersil, Kromasil, Inertsil, and Spherisorb. We can supply these materials in various dimensions; from 1mm ID to 50mm+, most popular lengths, stainless steel, and PEEK.We are also proud distributors of Upchurch Scientific fittings and fluid transfer supplies; and Ohio Valley (OV)
gc capillaries, packed columns, and
gc accessories. Call or E-mail us to order.
