主题:【求助】求教一些关于各种阀的问题
浏览0 回复19 电梯直达
文文
现在打算设计一个连续装置,一查资料,上面各种阀都把我弄晕了,不知道各种阀有什么区别,常见的有那些,比如背向阀,针型阀,截止阀,单向阀什么的,大家介绍点这方面的知识吧,多谢了
暴走追风
我介绍一下各种阀门的翻译!!!
阀门 valve lead; valve
阀门扳手 valve key
阀门操纵程序 valve management program
阀门尺寸 valve size
阀门的研磨 grinding-in of valve
阀门垫圈 valve washer
阀门定位器 pneumatic servo; valve positioner
阀门定位伺服回路 valve positioning servo loop
阀门杆 valve lever
阀门杆导路 guide for the valve rod
阀门钢 valve steel
阀门活塞 valve piston
阀门间隙 valve clearance
阀门键 valve key
阀门开度 valve opening
阀门控制 valve control
阀门控制机构 valve control mechanism
阀门密封 valve seal
阀门磨床 valve grinding machine
阀门碰撞 knocking of the valve
阀门切换型蓄热式 heat accumulating type of shift change
阀门升程 valve lift
阀门式给水栓 gate-type hydrant
阀门式消防龙头 gate-type hydrant
阀门室 valve box
阀门手轮 valve handle
阀门铣床 valve milling machine
阀门箱 valve box
阀门型式 valve type
阀门座 valve seat
adjusting valve
调整阀, 调节阀
admission valve
进气阀; 进浆阀
agitating valve
搅拌桨
air valve
(空)气阀
air admission valve
进气阀
air bleed(ing) valve
排气阀; 排气嘴
air control valve
空调阀
air cylinder valve
气筒阀
air escape valve
泄气阀
air inlet valve (=air intake valve)
进气阀; 进风阀
air pilot valve
空气导向阀
air pressure governor valve
风压调压阀
air relay valve
空气中继阀
air release valve (=air relief valve)
排气阀; 放空阀
air reversing valve
空气换向阀
air shut-off valve
空气关闭阀
air signal reducing valve
空气信号减压阀
air slide valve
空气分配阀
air starting (control) valve
空气起动(控制)阀
air straining check valve
空气滤尘止回阀
air vent valve
气动调压阀, 排气阀
air-actuated direction valve
气动控制换向阀
air-compressor valve
空气压缩机阀门
air-operated valve
气动阀
air-operated reversing valve
气动换向阀
air-vacuum change-over valve
空真转换阀
air-vacuum proportional valve
空真比例阀
air-vacuum two way valve
空真二位阀
alarm valve
报警阀
Allan valve
阿伦滑阀
altitude valve
【航空】高度阀(航空发动机汽化器的可调整阀)
ammonia valve
【工】氨阀
angle valve
角阀
angle back-pressure valve
背压角阀
angle globe valve
折角球形阀
angle stop valve
弯形止阀, 折角止阀
angle water valve
折角水阀
annular ring valve
环形阀; 环状阀
anti-g valve
【航空】防超重活门, 抗重力阀
antisurge valve
【航空】防喘振活门
application valve
作用阀, 控制阀
application pilot valve
作用导阀
ashpan blower valve
灰盘吹风阀
Askania valve
射流管阀
atmos valve (=atmospheric valve)
大气阀, 空气阀; 放空阀
auto tyre valve
汽车胎的汽门
autocontrol valve
自动控制阀
automatic valve
自动阀
automatic air valve
自动空气阀
automatic brake valve
自动制动阀
automatic control valve
自动控制阀
automatic cutout valve
自动切断阀门
automatic delivery control valve
自动输送控制阀
automatic drain valve
自动排水阀
automatic expansion valve
(定压式)自动膨胀阀
automatic gas sampling valve
自动气体进样阀
automatic reducing valve
自动减压阀(高速制动机)
automatic regulating valve
自动调节阀
automatic spring loaded valve
自动弹簧阀
automatic supplementary air valve
自动补充(空)气阀
automatic unloading valve
自动卸载阀
automatic water level valve
自动水准阀
automatically operated valve
自动操作阀
automatic-control servo valve
自动控制伺服阀
auxiliary valve
辅助阀(暖汽调整阀用)
auxiliary changeover valve
辅助切换阀
back valve
回动阀, 止回阀, 逆止阀, 单向阀
backflush valve
反冲阀
backlash valve
无游隙阀门
back-pressure valve
止回阀
back-up valve
列车后端制动阀
balance valve
平衡阀, 均压阀
balance pressure reducing valve
平衡减压阀
balance slide valve
平衡滑阀
balanced distribution valve
平衡配气阀
balanced safety valve
平衡式安全阀(可变动背压)
ball valve
球阀, 弹子阀
ball check valve
止回球阀, 球形节流阀
ball float valve
浮子阀, 浮球阀
ball non-return valve
球形止回阀
ball relief valve
球形安全阀
ball safety valve
球形安全阀
ball stop valve
球形止阀
ball-and-lever valve
杠杆球阀
bell valve
钟形阀, 装料钟
bellows valve
波纹管阀
bellows-operated pilot valve
膜盒控制导阀, 膜盒导引阀
bevel seat valve
斜座阀, 角阀
biased valve
承载阀
bigrid valve
双栅管
blast furnace gas valve
高炉煤气阀
blast regulation valve
通风调节阀
bleed valve
排出阀; 放泄阀
bleeder valve
放液阀, 放水阀
block valve
隔断阀
blocking valve
闭塞阀
blow valve
通风阀, 安全阀, 放空阀
blow-down valve
排气阀
blower valve
鼓风机阀
blower drain valve
鼓风机放泄阀
blower regulation valve
通风调节阀
blow-off valve
排出[泄]阀, 放泄[空]阀, 喷放阀
blowout valve
排气管, 排出阀
boiler check valve
锅炉止回阀
boiler feed valve
锅炉给水阀
bonnet valve
帽状阀
bottom valve
底阀
bottom drain valve
底部放泄阀
brachial valve
腕瓣
brake valve
制动阀
brake application valve
制动作用阀
brake application magnet valve
电磁制动阀
brake control valve
制动控制阀
brake cylinder release valve
制动缸缓解阀, 制动缸放风阀
brake metering valve
制动调节阀
brake pipe compensating valve
制动管补偿阀
brake release magnet valve
缓解电磁阀
brake-field valve
正栅管
brass valve
黄铜阀
brass-fitted cast-iron valve
黄铜配制铸铁阀
brass-trimmed valve
黄铜配制阀
breather valve
通气阀, 呼吸阀
breathing valve
呼吸瓣
breathing type safety valve
呼吸式安全阀(罐车)
bright emitter valve
白炽灯丝电子管, 钨丝电子管
brine retaining valve
盐水箱保持阀
bucket valve
活塞阀
buffer change valve
缓变阀
building block valve
积木式阀, 集成阀
built-in check valve
内装式单向阀
bullet valve
球阀
buried valve with key
液下控制阀
butterfly valve
蝶形阀
butterfly control valve
蝶形控制阀
butterfly throttle valve
蝶形节流阀
by-pass valve
旁通阀, 辅助阀, 回流阀
by-path valve
旁通阀, 辅助阀, 回流阀
cab turret valve
蒸汽塔总汽门
caboose valve
守车阀
cage type valve
笼形阀
cam-operated valve
凸轮控制阀
capless tyre valve
暴走追风
无帽胎阀
car discharge valve
车辆放风阀
car signal valve
车辆信号阀, 车辆放风阀
cardiac valve
【解】贲门瓣
cartridge inserted valve
筒式插装式阀, 插装阀
cement valve
【机】水泥止回阀
center valve
中心阀
centre bypass valve
中间位置旁通的换向阀, M型机能换向阀
centre spool valve
中心柱形阀
centrifugal saw plate valve
离心机的圆盘保险(溢流)阀
centrifugal type injection valve
离心式喷射阀
change valve
换向阀, 三通阀
changeover valve
活页阀
旋转阀, 转换阀
多向阀
charge valve
充气阀, 加载阀, 加液阀
charging valve
充气阀, 加载阀, 加液阀
charging check valve
充气止回阀
check valve
单向阀, 止回阀, 防逆阀
检验阀
chimney valve
烟道阀
choke valve
阻风门
choker checkvalve
阻气单向阀
cindervalve
卸灰阀
Cineston controller brake valve
钦式控制制动联合阀 (用于地下铁道)
circulating-water valve
循环水阀
circulation valve
环流阀
clack valve
止回阀
clapper valve
瓣阀
clock valve
单向绞链阀
closed center valve
中间位置封闭的阀(方向阀); 闭中心阀
closed crossover valve
正遮盖的换向阀
closed exhaust valve
密闭排气阀
closed-type fuel valve
密闭形燃油阀
closing valve
隔离阀, 节制阀, 隔断阀, 停汽阀
clutch application valve
离合器作用阀
clutch temperature adjusting valve
离合器温度调节阀
coasting valve
滑行阀, 惯性运动阀
coaxial valve
同轴管[阀]
cold water stop valve
凉水止阀
column valve
柱阀
column shut-off valve
柱关闭阀
column switching valve
柱转换阀
combination valve
组合阀
combination sliding and rotary spool valve
又移动又旋转的圆柱滑阀
combined inlet-outlet valve
进出组合阀
combined reheat (stop and intercept) valve
再热联合汽门, 中压联合汽门
combined strainer and check valve
混合滤尘止回阀
common slide valve
普通滑阀
compensated flow control valve
带压力补偿的流量控制阀
调速阀
compensated relief valve
平衡式溢流阀
compensating valve
补偿阀
compensating air valve
补充空气阀, 补偿气阀, 平衡气阀
compensation valve
平衡阀, 补偿阀
compression valve
(减振器的)压缩行程阀
compression release valve
减压阀
compressor valve
压气机气门
concentric valve
同心阀
condensate valve
凝结水阀
condenser valve
凝汽阀
condenser level control valve
凝汽器水位调节阀
condenser relief valve
凝气器安全阀
conductor's valve
车长阀, 紧急制动阀
cone valve
锥形阀
cone-way valve
单向阀
conical valve
锥形阀
conical seat valve
锥形座阀
constant pressure valve
恒压阀
constant pressure expansion valve
恒压膨胀活门, 恒压膨胀阀
control valve
控制阀, 调节阀
控制管, 调节管
control air valve
控制空气阀
control air type reducing valve
控制空气型减压阀
controllable check valve
可控单向[止回检验]阀
controller pilot valve
控制器管制阀
conversion valve
转换阀
转向阀
convex head valve
凸形气门头
cooled type valve
冷却式真空管
cooling fan electro-pneumatic valve
冷却风扇电空阀
coplanar-grid valve
共面栅极管(具有两个控制栅的四极管)
copying valve
(仿形装置的) 仿形阀
corner valve
角阀
coronary valve
【解】冠状瓣
counterbalance valve
背压阀,反平衡阀
coupling valve
联结阀
coupled valve
联结阀
crab-pot valve
捕蟹器式阀
crack valve
瓣阀
cranked tire valve
轮胎气嘴
cross valve
转换阀, 三通阀
cross feed valve
双向进给阀
crossover valve
交换阀, 转换阀
crossover gasoline valve
重叠的汽油阀
crystal valve
晶体管
cup valve
杯形阀, 钟形阀
cured-in valve
硫化在内胎里的气嘴[孔]
current regulating valve
电流调节阀
cushion valve
缓冲阀, 弹性阀, 减震阀
cushioned channel valve
气垫槽阀
cut slide valve
膨胀滑阀
cut-in valve
接入阀
cut-off valve
截止阀, 逆止阀
cut-off slide valve
断流滑阀
cut-out magnetic valve
截断电磁阀
cycle tube valve
循环管阀
cycling valve
循环阀(安全制动)
cycling solenoid valve
周期(工作的)电磁阀
cylinder valve
气缸阀
cylinder bypass valve
汽缸旁通阀
cylinder cock valve
汽缸排水操纵阀
cylinder drain valve
汽缸自动排水阀
cylinder relief valve
汽缸安全阀
cylinder test valve
汽缸(积水)试验阀
cylindrical valve
柱形阀
cylindrically balanced valve
柱形平衡阀
damping valve
阻尼阀;阻尼管
dark-tint valve
深色彩色电视管
dead-weight safety valve
静载荷保安阀
deck valve
台阀
decompression check valve
卸压单向阀
deflation valve
放气阀
deflection valve
射束偏转管
delivery valve
导出阀; 排气阀; 出油阀
delivery check valve
送油节止阀
density control valve
调浓阀; 浓度控制阀
deriming valve
解冻阀
detecting valve
检波管
detector valve
检波管
diaphragm valve
膜板阀, 隔膜阀; 针阀, 给水调整阀
diaphragm control valve
膜片控制阀
diaphragm cut-off valve
膜板截断阀
differential valve
差动阀
differential pressure fuel valve
压差油阀
differential pressure regulating valve
差压调节阀
differential relay valve
差动中继阀
differential sliding valve
差动滑阀
diffuser valve
扩散阀
diffusing type steam valve
扩压式汽阀
direct admission valve
直接进风阀
direct pressure control valve
直动式压力控制阀
direct-acting valve
直动阀
direct-acting control valve
直接作用控制阀
direct-acting solenoid valve
直接动作螺管阀
direct-mounted valve
管式连接阀
direction(al) control valve
方向控制阀
director valve
主导活门
disc valve
片状阀
discharge valve
排出阀;卸料阀
disconnecting valve
断流阀, 断开阀, 截止阀
disc-type reducing valve
暴走追风
盘式减压阀
diskvalve
盘形阀
distributing valve
分配阀
distributing slide valve
分配滑阀
distribution valve
分配阀
diverter valve
偏向型元件
分流阀
dividing valve
分流阀
dividing control valve
分配控制阀
dorsal valve
【解】背瓣
double valves
双阀
double branch stop valve
双向止流阀
double check valve
双止回阀, 双单向阀
double damper valve
双调节阀, 双减振阀
double gate valve
双闸阀
double ported valve
双口阀
double pressure feed valve
双压进给阀
double return valve
双止回阀, 双回流阀
double safety valve
双安全阀
double seat balanced valve
双座平衡阀
double seated main stop valve
双座式主汽门
double sleeve valve
双套阀
double slide valve
双动滑阀
double-anode valve
双屏极电子管
double-beat (drop) valve
双座阀, 双支承提升阀, 平衡阀
double-beat poppet valve
双层提升阀
double-face valve
双面阀
double-faced slide gate valve
两面滑门阀
double-grid valve
双栅管
double-heading valve
重联阀
double-piston valve
双活塞阀
double-ported slide valve
双动滑阀
double-purpose valve
【电子】双作用管
double-ring valve
双环阀
double-triode valve
双三极管
drain valve
排水阀;泄水阀
draw-off valve
排水阀;泄水阀
drip valve
排水阀;泄水阀
driver's automatic brake valve
司机自动制动阀
driver's vacuum brake valve
司机真空制动阀
drop valve
落阀
dropping valve
降压阀, 减压阀
drum valve
鼓形阀
dual ball check valve
双球止逆阀
dual-gravity valve
【化工】双比重阀
dump valve
倾泄阀(安全阀)
Duner flush valve
达式水阀
duplex check valve
双止回阀
duplex release valve
复式缓解阀
dynamic valve
动力阀
dynamic brake blending valve
动力制动混合阀
eccentric valve
偏心阀
effluent sample valve
试样流出阀
Eidophor light valve
艾多福光阀(电视投影机)
electric valve
整流管
electric control valve
电动调节阀
electric pneumatic valve
电空阀
electrically operated valve
电动阀
electrochemical valve
电解阀
electrohydraulic valve
电-液阀
electromagnetic valve
电磁阀
electromagnetic gas valve
电磁气阀
electromagnetic light valve
电磁(控制)光阀
electrometer valve
静电计电子管
electron valve
电子管
electronic valve
电子管
electrooptic light valve
电光光阀
electropneumatic valve
电动气动阀, 电磁气阀
electropneumatic carretarder valve
车辆减速器的电空阀, 车辆缓行器的电空阀
electropneumatic distributing valve
电动气动分配阀
electropneumatic signal valve
信号机电动气动阀
electro-pneumatic switch valve
转辙机电动气动阀
electropneumatic train stop valve
列车自动停车电动气动阀
emergency valve
安全阀
紧急阀
emergency application valve
紧急作用阀
emergency brake valve
紧急制动阀, 车长阀
emergency breakaway valve
紧急断气阀
emergency closing valve
应急阀
emergency pressure increasing valve
紧急增压阀
emergency pressure reducing valve
紧急减压阀
emergency relay valve
紧急继动阀
emergency stop valve
危急遮断阀, 紧急止流阀, 主汽门
emergency trip valve
危急遮断阀, 紧急止流阀, 主汽门
emergency trip magnet valve
紧急脱钩电磁阀
emergency vent valve
紧急放风阀
empty and load valve
空重车转换阀
empty wagon safety valve
空车安全阀
emptying valve
泄空阀, 排油阀
end valve
尾阀
end train-pipe valve
暖气管端阀
engine valve
发动机阀, 发动机[汽缸]气门
engine brake valve
机车制动阀
engine compartment drain valve
(发动)机舱放泄阀
engine stop valve
停车阀
engine thermostat housing drain valve
发动机恒温器壳放泄阀
engineer's brake valve
司机制动阀
equalizing valve
平衡阀, 均匀阀, 减压阀
equalizing discharge valve
均衡放风阀
equalizing graduating valve
均衡递动阀
equalizing piston valve
均衡鞲鞴阀
equalizing slide valve
均衡滑阀
equilibrated valve
预启阀, 压力平衡阀
equilibrium valve
平衡阀
equilibrium slide valve
平衡滑阀, 放泄滑阀
equivalent valve
等效电子管
escape valve
排气阀, 安全阀
eustachian valve
【解】腔静脉瓣, 欧氏瓣
excess flow valve
流量限制阀
excess pressure valve
过压阀
exhalation valve
吸气阀
exhaust valve
排气阀, 排气门
exhaust by-pass valve
排气旁通阀
exhaust manifold heat valve
排气歧管加热阀
exhaust steam valve
排汽阀
exhauster regulating valve
真空泵调节阀
expansion valve
膨胀阀; 安全阀
expansion valve with pilot valve
导向式自动膨胀阀
expansion relief valve
膨胀安全阀
explosion relief valve
防爆安全阀, 安全阀
explosive valve
爆发活门
extra-air valve
辅助气阀(附加空气阀)
extraction valve
抽汽阀
extraction check valve
抽汽逆止阀
extraction control valve
抽气调节阀
extraction regulating valve
暴走追风
抽气调节阀
extraction stop valve
抽汽截止阀
face valve
座阀
fast valve
高速阀, 快关阀
feather valve
放气阀, 卸载阀, 滑阀
feed valve
进给阀, 喂阀; 给气阀; 进水阀
feed check valve
给水止回阀
feed stop valve
进给安全阀
feed-control valve
进给控制阀
feed-regulating valve
进给调节阀, 给水调整阀
fermentation valve
发酵阀
field weakening valve
削弱磁场阀
field-strengthening valve
磁场加强阀
filling valve
进油阀
filling limit valve
充量限制阀
finger valve
(压缩机)单槽阀
fire valve
灭火阀, 消防阀
first amplifier valve
第一级放大管
fixed differential reducing valve
定差减压阀
flange type everlasting blow-off valve
凸缘式连续放泄阀
flanged brass valve
凸缘铜阀
flap valve
片状阀;瓣阀
flapper valve
(喷嘴)挡板阀, 舌形阀
flat valve
平面座阀, 配流阀
flat seated valve
平座阀
flat slide valve
平滑阀
flat-operated relief valve
浮筒操纵安全阀
flexible tube valve
挠性管阀
float valve
浮阀, 回压阀
float control(led) valve (=float controller valve)
浮子(控制)阀, 液面调节阀
float needle valve
浮针阀
float-operated relief valve
浮球控制安全阀
float-switch controlled rotary-spool valve
浮动开关控制的旋转滑阀
flood(ing) valve
溢流阀
flop valve
瓣阀
flow valve
流量开关
flow diversion valve
液流转向阀
flow metering valve
流量控制阀
flow regulating valve
节流阀, 减压阀
flow-control valve
流量控制阀
fluid pressure reducing valve
液压降低阀
fluid-control(led) valve
流体控制阀, 液力控制阀
flushing valve
冲洗阀
flush-out valve
冲出阀
flutter valve
翼形阀
follower valve
随动阀
follow-up valve
随动阀
foot valve
脚踩阀;底阀
forcing valve
增压阀
four-electrode valve
四极管
four way plug valve
四通塞阀
four-way valve
四通阀
frame output valve
帧信号输出管
free discharge valve
自由泄流阀
free flow valve
易流阀
free spool valve
带浮动阀芯的滑阀
frost valve
防冻阀
fuel valve
燃油阀
fuel admission valve
燃料进入阀
fuel control valve
燃料控制阀
fuel injection valve
燃油喷射阀
fuel outlet valve
放油阀
fuel-tank selector valve
燃油箱分离阀
ga(u)ge cock valve
水位旋塞阀
gasvalve
排气阀
gas admittancevalve
进气阀
gas and gasoline threeway valve
煤气与汽油三通阀
gas bleed valve
泄气阀
gas charging valve
充气阀(蓄能器)
gas check valve
闭气阀
gas control valve
气体调节阀
gas escape valve
煤气放气阀
gas inlet valve
进气阀
gas linking valve
燃气连结阀
gas oil solenoid valve
气体油料螺管阀
gas outlet valve
出气阀
gas precharge valve
充气阀
gas sampling valve
气体进样阀
gas-engine inlet valve
煤气机进气阀
gas-filled valve
充气管
gas-filling valve
充气阀
gasoline valve
汽油门
gas-tank valve
汽油箱汽门
gate valve
闸式阀, 闸门阀
gate gurgle valve
泄油阀
gate turn valve
旋转炉门
genital valve
生殖瓣
gland sealing steam control valve
汽封蒸汽调节阀
glass valves
玻璃阀
globe valve
球心阀
stop valve
球心阀
globe body valve
球形阀
globe stop valve
球形截流阀
governing valve
调速阀, 调节阀
governor valve
调速阀, 调节阀
governor magnet valve
调速器磁铁阀
governor slide valve
调节器滑阀
governor solenoid valve
调速器螺管阀
graduating valve
调节阀;节制阀; 阶段制动阀
greaseless valve
无脂密封阀
grid valve
栅型阀
gridironvalve
格子阀
grid-type extraction valve
栅型抽汽阀
groove control valve
槽式节流阀
group valve
组合阀, 阀组
grout valve
灌浆阀
guard's valve
车长阀, 紧急制动阀, 速动闸门, 事故阀, 停车开关
guard's van valve
守车制动阀
guide(ing) valve
导向阀
half ball valve
半球形阀
hand air valve
手控气阀
hand brake valve
手制动阀
hand by-pass valve
手动旁通阀
hand oiler valve
注油器手阀
hand-operated brake valve
手操纵制动阀
hand-operated direction valve
手动换向阀
hanging valve
吊阀
hard valve
高真空电子管, 硬性电子管
head valve
头阀
顶置阀
heat control valve
热控制阀, 加热控制阀
heat regulating valve
热调整阀
heart valve
【解】心(脏)瓣膜
heater shut-off valve
(火花塞)加热器断流阀
height control valve
高度控制阀
high power valve
大功率管
high pressure float valve
高压浮球阀
high side float valve
高压浮球阀
high-pressure expansion valve
高压膨胀阀
high-pressure safety valve
高压安全阀[瓣]
high-pressure slide valve
高压滑阀
high-speed needle valve
高速针阀
high-speed reducing valve
高速减压阀
high-vacuum valve
高真空整流管
hinged valve
瓣阀
hoist cylinder oil relief valve
起重机油缸油压安全阀
hoist pump check valve
起重机油泵止回阀
hoist pump control valve
起重机油泵操纵阀
holding valve
闭锁阀, 止回阀, 单向阀
hollow-jet needle valve
空注针形阀
homogenizing valve
均质机高压阀
horizontal valve
水平阀
hose valve
水带阀门
hot water regulating valve
水温调整阀
hot water stop valve
热水止阀
hot-blast valve
热风阀
hot-cathode gas filled valve
闸流管
hot-water check valve
热水止回阀
hull valve
舷侧阀, 通海阀
hydrant valve
消防龙头阀
hydraulic valve
液压阀, 调水活门
hydraulic back pressure valve
水保险器(焊接)
hydraulic control valve
液压控制阀
hydraulic relay valve
液压继动阀
hydraulic sequence valve
液压顺序阀
hydraulic speed setting valve
液力定速阀
hydraulic-brake operating valve
液力制动操纵阀
hydraulically balanced valve
液压[液力]平衡阀
hydraulically operated direction control valve
液压操纵的方向控制阀, 液动换向阀
hydrodynamic brake valve
液力制动阀
hydrostatic valve
静水压力阀; (鱼雷)水压仪;定深仪
idling control valve
空转控制阀
ileal valve
暴走追风
CQ螺纹球阀 CQ Thread Ball Valves
L形三通式 L-pattern three way
T形三通式 T-pattern three way
安全阀 Safety valve
暗杆闸阀 Inside screw nonrising stem type gate valve
百叶窗; 闸板 shutter
百叶窗式挡板 louver damper
摆阀式活塞泵 swing gate piston pump
保温式 Steam jacket type
报警阀 alarm valve
报警阀; 信号阀; 脉冲阀 sentinel valve
背压调节阀 back pressure regulating valve
背压率 Rate of back pressure
本体阀杆密封 body stem seal
波纹管阀 Bellows valves
波纹管密封阀 bellow sealed valve
波纹管密封式 Bellows seal type
波纹管平衡式安全阀 Bellows seal balance safety valve
波纹管式减压阀 Bellows reducing valve
波纹管式减压阀 Bellows weal reducing valve
薄膜 thin film
薄膜; 隔膜 diaphragm
薄膜式减压阀 Diaphragm reducing valve
薄型闸阀 Thin Gate Valves
不封闭式 Unseal type
槽车球阀 Tank Lorry Ball Valves
颤振 Flutter
常闭式 Normally closed type
常开式 Normally open type
超低温阀门 Cryogenic valve
超高压阀门 Super high pressure valve
超过压力 Overpressure of a safety valve
衬胶隔膜阀 rubber lined diaphragm
衬胶截止阀 rubber lined globe valve
垂直板式蝶阀 Vertical disc type butterfly valve
磁耦合截止阀 Magnetic Co-operate Globe Valves
带补充载荷的安全阀 Supplementary loaded safety valve
带辅助装置的安全阀 Assisted safety valve
单阀碟双面平行密封闸阀 parallel single disk gate valve
单口排气阀 Single Opening Exhaust Valves
单向阀 Non-return Valve
单闸板 Single gate disc
单闸板平板闸阀 Single Disc Flat Gate Valves
弹簧薄膜式减压阀 Spring diaphragm reducing valve
弹簧式安全阀 Direct spring loaded safety valve
弹簧座 Spring plate
弹性闸板 Flexible gate disc
当量计算排量 Equivalent calculated capacity
挡板 damper
导阀 Pilot valve
导向套 Valve guide disc guide
低温阀门 Sub-zero valve
低压阀门 Low pressure valve
底阀 bottom valve
底阀 Foot valve
电磁动装置 Eletro magnetic actuator
电磁阀 magnetic valve
电磁阀 solenoid valve
电磁-液动装置 Eletro magnetichydraulic actuator
电动阀 mortor operated valve
电动阀 motorized valve
电动截止阀 Electric Actuated Stop Valves
电动平行式双闸板闸板 Electric Double Disk Parallel Gate Valves
电动楔式闸阀 Electric Actuated Wedge Gate Valves
电动装置 Electric actuator
电-液动装置 Eletro hydraulic actuator
电液伺服阀 electro-hydraulic servovalve
调节弹簧 Regulation spring
调节阀 adjusting valve
调节阀 control valve
调节阀 regulating valve
调节螺套 Adjusting bolt Adjusting screw
调节圈 Adjusting ring
蝶板 Disc
蝶阀;瓣阀 butterfly valve
蝶阀;瓣阀;拍门;铰链阀 flap valve
蝶式缓冲止回阀 Butterfly Type Non-slam Check
蝶式止回阀 Butterfly swing check valve
定比减压阀 Proprutioning pressure reducing valve
定差减压阀 Fixed differential reducing valve
定值减压阀 Fixed pressure reducing valve
动态特性 Dynamic characteristics
对焊连接阀 Buttwelding valves
对夹蝶板阀 Wafer plate valves
对夹式衬胶蝶阀 Wafer Type Butterfly Valves with Rubber Itning
对夹式阀门 Clamp valves
对夹式止回阀 Wafer Check Valves
额定排量 Certified capacity
额定排量系数 Derated coefficient of discharge
二通阀 Two-way valves
阀 valve
阀板 valve deck plate
阀板 valve plate
阀板式活塞泵 valve deck plate type piston pump
阀板式活塞泵 valve plate type piston pump
阀瓣 Disc
阀操纵杆 valve operating rod
阀痤槽 valve seat recess
阀挡 valve grid
阀挡 valve positioner
阀挡 valve stop
阀导杆 valve tail rod
阀导向器 valve guide
阀盖 bonnet
阀盖衬套 bonnet bush
阀盖垫片 bonnet gasket
阀杆 stem
阀杆 valve rod
阀杆 valve spindle
阀杆端部尺寸 Dimmension of valve stem end
阀杆环 stem ring
阀杆螺母 Yoke bushing Yoke nut
阀杆填料 stem packing
阀杆头部尺寸 Dimension of valve stem head
阀簧 valve spring
阀簧压板 valve spring plate
阀控水锤泵 valve-controlled hydraulic ram
阀框架 valve yoke
阀门 Valve
阀门传动装置 valve bandle set
阀门和管件 Valves and Fittings
阀门盘根 valve packing
阀门手柄 valve handle
阀盘 disc
阀盘 valve disc
阀片 Disc
阀球 valve ball
阀驱动臂 valve driving arm
阀驱动臂 valve motion arm
阀式活塞 valve type piston
阀式活塞 valve type bucket
阀室式活塞泵 valve box type piston pump
阀室式活塞泵(美) valve pot type piston pump
阀抬起装置 valve lifting device
阀体 body
阀体 valve body
阀箱 valve box
阀箱 valve cage
阀箱 valve chest
阀箱;阀限位器 valve guard
阀箱盖 cover for valve box
阀箱盖 valve box cover
阀箱式活塞泵(美) turret type piston pump
阀形活塞泵 valve type piston pump
阀座 Seat ring
阀座 valve carrier
阀座 valve seat(body seat)
阀座;阀盘 valve seat
阀座环 seat ring
阀座密封嵌条 sealing strip for valve seat
法兰 flange
法兰堵头 blind flange
法兰端 flange end
法兰接头 flange joint
法兰连接紧固件(双头螺栓和螺帽) flange bolting
法兰密封面,法兰面 flange facing
法兰面加工 flange facing finish
法兰球阀 Flange Ball Valves
翻板阀 Flap
反冲盘 Disc holder
反向作用式减压阀 Reverse acting reducing valve
放空阀 emptying valve
放气阀 air vent valve;vent valve
放气阀;排气阀 air evacuation valve
放泄阀 escape valve
分置阀室式活塞泵 separate valve box type piston pump
分置阀室式活塞泵(美) side pot type piston pump
封闭式 Seal type
浮动式球阀 Float ball valve
浮球 Ball float
浮球阀 Float Valve
浮球式疏水阀 Ball float steam trap
浮球式疏水阀 Free Float Type Steam Trap
浮桶 Bucket float
浮桶式疏水阀 Open bucket steam trap
暴走追风
辅助(副)阀 Auxiliary valves
负荷率 Rate of load condensate
附加背压力 Superimposed back pressure
复位弹簧 Returnning spring
杠杆式 Lever type
杠杆式安全阀 Lever and weight loaded safety valve
杠杆式减压阀 Lever reducing valve
高温阀门 High temperature valve
高压阀门 High pressure valve
格兰密封 gland
隔离阀 isolating valve
隔膜 Diaphragm
隔膜阀 diaphragm valve
隔膜式控制阀 diaphragm operated comtrol valve
工作背压 Operating back pressure
工作温度 Operating temperature
工作温度 Working temperature
工作压差 Operting differential pressure
工作压力 Operating pressure
工作压力 Working pressure
公称通径 Nominal diameter
公称压力 Nominal pressure
固定式球阀 Fixed ball valve
关闭压力 Lockup pressure
关阀过冷度 Subcooled temperature of close valve
关阀温度 Closing valve temperature
管道安全阀 Piping Safety Valves
过冷度 Subcoold temperature
过流阀(或节流阀) Restrictor Valves
喉径 Throat diameter
滑阀 slide valve
滑阀式回转活塞泵 rotary piston pump with slide gate
滑阀型转子泵 eccentric rotary pump with sliding sleeve
环形阀 annular valve
环形阀 double beat valve
换向阀 selector valve
换向阀 shuttle valve
回转滑阀活塞泵 piston pump with rotary gate
回座压力 Re-seating pressure of a safety valve
活塞昵减压阀 Piston reducing valve
活塞式阀 piston valve
活塞式阀;柱塞式阀 plunger valve
活塞式减压阀 Piston reducing valve
减速阀 Deceleration valves
减压比 Pressure reducing ratio
减压阀 pressure reducing valve
浆液阀 Parallel Slide Valves
角阀 Angle Valve
角阀 isolation valve angle configuration
角式 Angie type
角式节流阀 Angle Throttle Valves
角式截止阀 Angle Stop valves
铰链阀;片状阀 flapper valve
节流阀 throttle valve
节流阀 choke valve
节流阀;节流 throttle
结构长度 Face-to-face dimension ;End-to-end dimension; Face-to-centre dimension
结构形式 Type of construction
截止阀 Globe valve
截止阀 Shut-off Valve
截止阀;关断阀 shut-off valve
截止式隔膜阀 Globe diaphragm valve
紧急切断阀 Emergeny Cut-off Valves
进气阀 air intake valve
进水阀;进口阀门 inlet valve
静态特性 Static characteristics
静态特性偏差 Static characteristics derivation
开阀过冷度 Subcooled temperature of open valve
开阀温度 Opening valve temperature
开启高度 Lift
壳体试验 Shell test
壳体试验压力 Seal test pressure
空气阀门 Air valves
快速排污阀 Quick Draining Valves
类型 Type
冷凝结水排量 Cold condensate capacity
冷态试验差压力 Cold differential test pressure
理论排量 Theoretical flowing capacity
连接槽尺寸 Dimension of connecting channel
连接尺寸 Conncetion cimension
连接形式 Type of connection
帘面积 Curtain area
流道面积 Flow area
流道直径 Flow diameter
流量孔板 flow orifice plate
流量控制阀 flow control valve
流量特性 Flow characteristics
流量特性偏差 Flow characteristics derivation
漏汽量 Steam loss
脉冲式疏水阀 Impulse steam trap
密封面 Sealing face
密封试验 Seal test
密封试验压力 Seal test pressure
明杆平行式双闸板闸板 Double Disk Parallel Gate Valves
明杆闸阀 Outside screw stem rising through handwheel type gate valve
膜片 Diaphragm
内压自封 Pressure seat
逆止阀;止回阀 check valve
逆止阀;止回阀 non-return valve
逆止阀;止回阀;单向阀 check valve
排放背压力 Brilt-up back pressure
排放压力 Relieving pressure
排灰阀 Ash valves
排量系数 Coefficient of discharge
排气阀 air release valve
排气阀 Exhaust valves
排气阀 Vent Valve
排水阀 Drainage valves
排水温度 Temperature at discharging condensate
排污阀 blowdown valve
排污箱(阀) Waste Valves
排渣闸阀 Scum Gate Valves
盘阀 moushroom valve
盘状阀 plate valve
旁路阀 by pass valve
配汽活塞阀缸套 piston valve line
喷射阀 injection valve
喷射阀 sprayer valve
喷水阀 spray water valve
频跳 Chatter
平衡阀 Balance valves
平衡式 Balance type
平行式闸阀 Parallel gate valve Parallel slide valve
启闭件 Disc
启闭压差 Blowdown of a safety valve
起始升程 Commencement of lift
气动装置 Pneumatic actuator
气阀摇臂 valve arm
气-液动装置 Pneumatic-hydraulic actuator
潜水电泵(排污泵) Submerged Motor Pumps
切断阀;截止阀 block valve;shut-off valve;stop valve
切断式止回阀 stop check valve
切换阀;多向阀 changeover valve
球、球芯 Ball
球阀 Ball valve
球阀 globe valve
球体 Ball
全启式安全阀 Fall lift safety valve
热凝结水排量 Hot condensate capacity
入口隔离门 suction isolating valve
塞子 Plug
三通阀 three-way isolating valve
三通阀 three-way valve
三通式 Three way type
上密封 Back seat
上密封试验 Back seal test
渗漏量 Leckage
升降立式止回阀 Vertical lift check valve
升降式止回阀 Lift check valve
适用介质 Suitable medium
适用温度 Suitable temperature
手摇油泵(阀) Manual Oil Pumps Valves
疏水阀 drain valve
双金属片式疏水阀 Bimetal elements steam trap
双口排气球 Double Opening Exhaust Valves
双联弹簧式安全阀 Duplex safety valve
双闸板 Double gate disc
双闸板平板闸阀 Double Disc Flat Gate Valves
水封闸阀 Water Seal Gate Valves
水力喷射器(真空泵) Vacuum Pumps
伺服阀 servovalve
填料 Packing
填料垫 Packing seat
填料函 Stuffing
填料式旋塞阀 Gland packing plug valve
填料箱 Stuffing box
填料压盖 Gland
通气阀 breather valve
通气阀;呼吸器 breather
通用阀门 General valve
吐出阀;排出阀 discharge valve
吐出阀限位器 delivery valve guard
微启式安全阀 Low lift safety valve
微阻缓闭止回阀 Tiny Drag Slow Shut Check Valves
吻合度 Percent of contact area
暴走追风
蜗轮传动蝶阀 Butterfly Valves with Gear Actuator
蜗轮传动装置 Wormgear actuator
屋脊式隔膜阀 Weir diaphragm valve
无阀泵 valveless pump
无阀隔膜泵 valveless diaphragm pump
无阀振动泵 valveless vibration pump
无负荷漏汽量 No-load steam loss
无负荷漏汽率 Rate of no-load steam loss
吸(抽)气阀 Aspirating valves
吸入阀 suction valve
吸入阀限位器 suction valve guard
先导式安全阀 Pilot operated safety valve
先导式液压阀 Pilot-operated reducing valve
相对静偏差 Relative static characteristics derivation
相对流量特性偏差 Relative flow characteristics derivation
相对压力特性偏差 Relative pressure characteristics derivation
销轴 Hinge pin
楔式闸阀 Wedge gate valve
斜板式蝶阀 Indined disc butterfly valve
泄料(放空,排污)阀 Blowdown valves
泄压阀 Decompression valves
泄压阀 pressure release valve
泄压阀;安全阀 relief valve
卸荷式减压阀 Balanced reducing valve
型号 Type Model
旋启多瓣式止回阀 Multi-disc swing foot valve
旋启式止回阀 Swing check valve
旋启双瓣式底阀 Double disc swing foot valve
旋塞阀 Cock
旋塞阀 plug valve
压力(増压)阀 Pressure valve
压力调节阀;压力控制阀 pressure controlled valve
压力特性 Pressure characteristics
压力特性偏差 Pressure characteristics derivation
压力增长系数 Pressure increasing ratio
摇杆 Arm
液动装置 Hydraulic actuator
液化气管件 LPG Pipe Fitting
液下泵 Under Water Pumps
液压执行器 hydraulic actuator
仪表针形截止阀 Meter Needle Type Globe Valves
溢流阀 overflow valve
翼形阀;锥形阀 wing valve
油封式旋塞阀 Lubricated plug valve
有阀翼板 double acting wing
有阀翼板 wing with valve
有负荷漏汽量 Load steam loss
有负荷漏汽率 Rate of load steam loss
圆板阀;圆盘阀 disc valve
圆盘式疏水阀 Shemostatic team trap
圆柱齿轮传动装置 Cylindrical gear actuator
圆锥齿轮传动装置 Conical gear actuator
闸板 Wedge disc
闸板式隔膜阀 Wedge diaphragm valve
闸阀 gate valve
闸阀 sluice valve
针形阀 Pintle valve ; Needle valve
真空破坏阀 vacuum breaker valve
蒸汽疏水阀 Automatic steam trap Trap
整定压力 Set pressure
正向作用式减压阀 Direct acting reducing valve
支架 Yoke
直接载荷式安全阀 Direct loaded safety valve
直接作用式减压阀 Direct-acting reducing valve
直流式 Y-globe type
直流式截止阀 Oblique Stop Valve
直通单向阀 inline check valve
直通单向阀 straightway check valve
直通阀 Throughway Valve
止回阀 Check Valve
止回阀;回流阀 reflux valve
制动阀 Brake valves
中压阀门 Middle pressure valve
钟形浮子式疏水阀 Inverted bucket steam trap
钟形罩 Inverted bucket
轴套 Axis Guide
主阀 Main valve
主要外形尺寸 Prime out-form dimensions
主要性能参数 Specifeca tion speeification
注液漏斗阀 Priming Tundish Valve
柱塞阀 Plunger valve
柱塞截止阀 Plunger Globe Valve
柱塞型摆动阀 rocking plunger valve
撞击手轮 Impact handwheel
锥形阀;翼形阀 conical valve
自动循环阀 Automatic Recirculation Valve
组合阀 Combination valves
最大过冷度 Maximum subcoold temperature
最大流量 Maximum flow rate
最大压差 Maximum differential pressure
最低工作压力 Minimum operating pressure
最高背压率 Maximum rate of back pressure
最高工作背压 Maximum operating back pressure
最高工作温度 Maximum operating temperature
最高工作压力 Maximum operating pressure
最高排水温度 Maximum temperature at discharging
最高允许温度 Maximum allwable temperature
最高允许压力 Maximum allowable pressure
最小过冷度 Minimum subcooled temperature
最小压差 Minimum differntial pressure
暴走追风
针型阀的介绍
仪表针型阀是仪表测量管路系统中重要组成部分,主要有截止阀和球阀,其功用是作开启或切断管道通路用。
    卡套式仪表阀门具有安装拆卸方便、连接紧固、有利于防火、防爆和耐压能力高、密封性能良好等优点,是电站、炼油、化工装置和仪表测量管路中的一种先进连接方式的阀门。
    针形截止阀的密封性良好,使用寿命长,即使密封面损坏后,也只需要更换易损零件,即可继续使用。
    安装时应使介质的流向与阀体上的箭头方向一致。
    手动截止阀、球阀可安装在管路的任何位置上。
暴走追风
一 阀门的定义:
  “阀”的定义是在流体系统中,用来控制流体的方向、压力、流量的装置。阀门是使配管和设备内的介质(液体、气体、粉末)流动或停止、并能控制其流量的装置。
二 根据启闭阀门的作用不同,阀门的分类方法很多,这里介绍下列几种。
1. 按作用和用途分类
  (1) 截断阀:截断阀又称闭路阀,其作用是接通或截断管路中的介质。截断阀类包括闸阀、截止阀、旋塞阀、球阀、蝶阀和隔膜等。
  (2) 止回阀:止回阀又称单向阀或逆止阀,其作用是防止管路中的介质倒流。水泵吸水关的底阀也属于止回阀类。
  (3) 安全阀:安全阀类的作用是防止管路或装置中的介质压力超过规定数值,从而达到安全保护的目的。
  (4) 调节阀:调节阀类包括调节阀、节流阀和减压阀,其作用是调节介质的压力、流量等叁数。
  (5) 分流阀:分流阀类包括各种分配阀和疏水阀等,其作用是分配、分离或混合管路中的介质。
2. 按公称压力分类
  (1) 真空阀:指工作压力低于标准大气压的阀门。
  (2) 低压阀:指公称压力PN ≤1.6Mpa 的阀门。
  (3) 中压阀:指公称压力PN 为2.5、4.0、6.4Mpa的阀门。
  (4) 高压阀:指工称压力PN 为10~80Mpa的阀门。
  (5) 超高压阀:指公称压力 PN≥100Mpa的阀门。
3. 按工作温度分类
  (1) 超低温阀:用于介质工作温度 t<-100℃的阀门。
  (2) 低温阀:用于介质工作温度-100℃≤t≤-40℃的阀门。
  (3) 常温阀:用于介质工作温度-40℃≤t≤120℃的阀门。
  (4) 中温阀:用于介质工作温度120℃
  (5) 高温阀:用于介质工作温度t>450℃的阀门。
4. 按驱动方式分类
  (1) 自动阀是指不需要外力驱动,而是依靠介质自身的能量来使阀门动作的阀门。如安全阀、减压阀、疏水阀、止回阀、自动调节阀等。
  (2) 动力驱动阀:动力驱动阀可以利用各种动力源进行驱动。
电动阀:借助电力驱动的阀门。
气动阀:借助压缩空气驱动的阀门。
液动阀:借助油等液体压力驱动的阀门。
此外还有以上几种驱动方式的组合,如气-电动阀等。
  (3) 手动阀:手动阀借助手轮、手柄、杠杆、链轮,由人力来操纵阀门动作。当阀门启闭力矩较大时,可在手轮和阀杆之间设置此轮或蜗轮减速器。必要时,也可以利用万向接头及传动轴进行远距离操作。
    综上所述,阀门分类方法是很多的,但主要是按其在管路中所起的作用进行分类。工业和民用工程中的通用阀门可分成11类,即闸阀、截止阀、旋塞阀、球阀、蝶阀、 隔 膜阀、止回阀、节流阀、安全阀、减压阀和疏水阀。其他特殊阀门,如仪表用阀、液压控制管路系统用阀,各种化工机械设备本体用阀等,均不在本书介绍范围以内。
5. 按公称通径分类
  (1)小通径阀门:公称通径DN≤40mm的阀门。
  (2)中通径阀门:公称通径DN为50~300mm的阀门。
  (3)大通径阀门:公称阀门DN为350~1200mm的阀门。
  (4)特大通径阀门:公称通径DN≥1400mm的阀门。
6. 按结构特征分类
  (1)截门形:启闭件(阀瓣)由阀杆带动沿着阀座中心线作升降运动;
  (2)旋塞形:启闭件(闸阀)由阀杆带动沿着垂直于阀座中心线作升降运动;
  (3)旋塞阀:启闭件(锥塞或球) 围绕自身中心线旋转;
  (4)旋启阀:启闭件(阀瓣) 围绕座外的轴旋转;
  (5)蝶行:启闭件(圆盘) 围绕阀座内的固定轴旋转;
  (6)滑阀行:启闭件在垂直于通道的方向滑动。
7. 按连接方法分类
  (1)螺纹连接阀门:阀体带有内螺纹或外螺纹,与管道螺纹连接。
  (2)法兰连接阀门:阀体带有法兰,与管道法兰连接。
  (3)焊接连接阀门:阀体带有焊接坡口,与管道焊接连接。
  (4)卡箍连接阀门:阀体带有夹口,与管道夹箍连接。
  (5)卡套连接阀门:与管道采用卡套连接。
  (6)对夹连接阀门:用螺栓直接将阀门及两头管道穿夹在一起的连接形式。
8. 按阀体材料分类
  (1)金属材料阀门:其阀体等零件由金属材料制成。如铸铁阀、碳钢阀、合金钢阀、铜合金阀、铝合金阀、铅合金阀、钛合金阀、蒙乃尔合金阀等。
  (2)非金属材料阀门:其阀体等零件由非金属材料制成。如塑料阀、陶 阀、搪 阀、玻璃钢阀等。
  (3)金属阀体衬里阀门:阀体外形为金属,内部凡与介质接触的主要表面均为衬里,如衬胶阀、 衬塑料阀、衬陶阀等。
amou83
