LFV Multipurpose Dynamic and_Fatigue Systems up to 3000 kN
Walter b Servohydraulic Multipurpose LFV Series are versatile and high-performance Test Systems available in different, robust configurations
covering a wide range of monotonic, dynamic and fatigue applications in the Aircraft & Aerospace, Automotive, Biomedical, Steel, Fastener, Rail or Marine industries as well Civil Engineering and R&D Testing Laboratories world-wide.
These servohydraulic systems are indispensable units of many laboratories in the field of quality control, product development or scientific research.
The LFV Servohydraulic Test Systems are modular constructed, covering the full spectrum of tests requirements and can be configured to a wide range of different test setups including TMF (Thermo-Mechanical Fatigue), LCF (Low-Cycle Fatigue), Fracture Mechanics, HCF (High-Cycle Fatigue), high-strain rate as well as component, manufacturing assemblies and finished goods testing.
Depending on application we offer high stiffness, ergonomic and reliable load frames with actuators integrated in the machine base or mounted on upper crosshead.
The LFV series can be configured with a variety of grips and fixtures, extensometers, environmental simulation chambers and furnaces, different software packages and other accessories to suit your specific testing needs.
Key Features
Latest digital control electronics with closed loop control and high data acquisition rate, and self-identification transducer coding
Rigid machine frame with high stiffness, provides superior axial and lateral stiffness and guarantees robust, durable and long-term operation
Increased stiffness means higher efficiency, as the amount of energy needed to overcome the frame deformation in each loading cycle is less
To increase the stiffness。
