原文由 happymingxu 发表:
Directions For Use
Heifers Fed in Confinement for Slaughter: MGA 200 Premix (Type A Medicated Article) should be thoroughly mixed in the supplement to provide 0.25 to 0.50 mg of melengestrol acetate per head per day. Average daily intakes approximating the middle of this range provide the most optimal and economical improvements in rate of gain and feed utilization. Constant daily intakes of 0.35 to 0.50 mg per head per day give a high degree of estrus suppression. Levels of 0.25 to 0.35 mg provide a lower but still effective degree of estrus suppression.
Heifers Intended for Breeding: MGA 200 Premix (Type A Medicated Article) should be thoroughly mixed in the supplement to provide 0.5 mg of melengestrol acetate per head per day.
使用方法:
用于舍饲供食用的小母牛:以甲烯雌醇乙酸酯计,将0.25至0.50毫克/头/日。平均每日摄入量逼近中间这个范围,将提供最优化和经济效益的改善率增益 ,并能提高饲料利用率。每日每头的摄入量为0.35至0.50毫克,能高度抑制发情;每日每头的摄入量为较低水平的0.25至0.35毫克时, 在一定程度上仍然能抑制发情。用于育种的母牛:以甲烯雌醇乙酸酯计,0.5毫克/头/日.
这段是我自己翻译的,请高手指点一二!谢谢!
供屠宰用的舍饲小母牛:将MGA 200预混剂(A 类加药)充分混合在补充料中,剂量按甲烯雌醇乙酸酯计为0.25至0.50毫克/头/日。平均每日摄入量接近上述剂量的中间值时,将在增重和饲料利用率上发挥最优和最经济的作用。长期每日每头摄入量为0.35至0.50毫克时,能强力抑制发情;每日每头的摄入量为较低水平的0.25至0.35毫克时, 在一定程度上仍然能抑制发情。
繁殖用小母牛:将MGA 200预混剂(A 类加药)充分混合在补充料中,剂量按甲烯雌醇乙酸酯计为0.5毫克/头/日.
对比一下看可有区别,你可以先翻译,我给你修改,好么??
