主题:【讨论】预留座位是否应该译为"reserved seat"还是直接写reserved?
浏览0 回复32 电梯直达
六脉神剑
如果给某人预留座位,是否将预留座位译为"reserved seat"或者直接写reserved?
各位大侠给指点一二!
happyjyl
可以用reserved seat。预留座位的票是reserved-seat ticket。
闲鹤野云
原文由 quanbaogang 发表:
各位大侠给指点一二!
It is reserved.  or This is a reserved seat. This seat is reserved.  or Can you please reserve one room for us, we will be there in, say, half an hour.
六脉神剑
谢谢两位,我最后还是打算用”RESERVED“。因为我要打印出来贴在座位上,简练的表达是最合适的。大家的意思呢!?
茅茅
茅茅
突然想到一个词:engaged. 应该也是这个意思吧?参与讨论,不敢自称为大侠。
happyjyl
六脉神剑
I appreciate your help! You all are very learned and warmhearted!
Last edit by quanbaogang
闲鹤野云
原文由 quanbaogang 发表:
I appreciate your help! You all are very learned and wormhearted!
not wormhearted but warmhearted.4, All of you are learned and ...
mfxhuang
何当奇
re•served  (r -zûrvd )
adj.
1. Held in reserve; kept back or set aside.
2. Marked by self-restraint and reticence. See Synonyms at silent.
re•serv ed•ly (-zûr v d-l ) adv.
re•serv ed•ness n.
The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2003. Published by Houghton Mifflin Company. All rights reserved.
ThesaurusLegend:  Synonyms Related Words Antonyms
Adj.    1.    reserved - set aside for the use of a particular person or party
unreserved - not reserved
2.    reserved - marked by self-restraint and reticence; "was habitually reserved in speech, withholding her opinion"-Victoria Sackville-West
backward - (used of temperament or behavior) marked by a retiring nature; "a backward lover"
undemonstrative - not given to open expression of emotion
inhibited - held back or restrained or prevented; "in certain conditions previously inhibited conditioned reactions can reappear"
restrained - under restraint
unreserved - not cautious or reticent; "unreserved behavior"
3.    reserved - cool and formal in manner
restrained, reticent, unemotional
