DICHLORVOS ICSC Boiling point at 2.7 kPa: 140癈 Relative density (water = 1): 1.4 Solubility in water: moderate Vapour pressure, Pa at 20癈: 1.6 Flash point: >80癈 Octanol/water partition coefficient as log Pow: 1.47
Physicochemical properties of pure dimethoate FAO specification Melting point technical 45-47ºC Boiling point 117ºC at 0.1 mm Hg Decomposition temperature rapid at >80ºC
CARBARYL Decomposes below boiling point Melting point: 142癈 Density: 1.2 g/cm?BR>Solubility in water, g/100 ml at 30癈: 0.004 - 0.012 very poor Vapour pressure, Pa at 20癈: negligible Flash point: 193-202癈 Octanol/water partition coefficient as log Pow: 1.59
