原文由 ghost555 发表:
对不起呦,唉,这边似乎都是做药检分析的,太专业了!
重新学习了下,在USP TESTS AND ASSAYS 通则里,提到:
Temperatures— Unless otherwise specified, all temperatures in this Pharmacopeia are expressed in centigrade (Celsius) degrees, and all measurements are made at 25. Where moderate heat is specified, any temperature not higher than 45 (113 F) is indicated. See Storage Temperature under Preservation, Packaging, Storage, and Labeling for other definitions.
BTW,问下,这边有做产品国际注册的吗?在哪个版块呀?
