原文由 christe 发表:
校准方法:比较法
校准原理: 在同样测量温度和使用同样转子, 转速, 对于同一系列, 可测量出同样的黏度值和扭矩读数. 通过与RVMASTER标准机读数几表, 可判断出被校准仪器是否准确. 标准: RVMASTER标准机读数与被校准仪器读数相差不得大于1.0
我试着翻译一下,不一定准确,就当是起一个抛砖引玉的作用吧(欢迎大家多多拍砖)
Method: Comparison method
Principle: For the same series, the same quantity of viscosity and torque could be measured with the same temprature and spindle. By comparing with the value of RVMASTER measured, the instrument which is under calibration could be judged whether it is accurate or not.
Specification: The difference should be not more than 1.0 of the measured value of RVMASTER and of the instrument being calibrated.
