主题:【求助】这个审稿意见该如何回复?
zhouxiaoming
前不久投了一个还算可以的杂志文章,审稿意见回来后还算是客观的,表示按照要求修改后可以考虑接收,但是审稿意见中有一条却总是看不太明白,我也征求了一些同行的意见,都没有给我明确的结论,所以感觉很头痛,眼看返稿期限已经不远,而过年回家的车票也已经预定,我觉得认真对待审稿人意见是非常重要的,不可能模糊回答.因此在坛子里请求大家的帮助.给我看看,出点主意.
该条审稿意见如下:
It is important to present the calibration graphs in investigations such as these as the shape of the graph can be useful to other researchers. Indeed, it is not clear from the text how the limits of the linear range were determined. Do the graphs roll over at either end or are these limits set because no solutions outside this range were investigated?
我对审稿人意见的理解(不太确定):
1 审稿人认为我应该把定标曲线以图的形式画出来(而我查阅了大量文献发现基本上都是文本的描述,比如y=aX+b,在本文中我也是如此)
2 审稿人认为我的线性限定义的不清楚(都是怎么定义的?)
3审稿人的疑问是:是否我只是对我线性范围之内的样品进行了测定?(我不太懂这句话:Do the graphs roll over at either end or are these limits set because no solutions outside this range were investigated?)
nini2006
呵呵,我也不懂,关注ing .希望高手给答案,让我也学一下.
