主题:【求助】谁能帮我把这些摘要译成英文?
浏览0 回复20 电梯直达
glzjssxl
该帖子已被ruojun设置为精华;
对国标甜蜜素的测定方法进行改进;
样品处理时以静置取代吸出正己烷层离心;
标准曲线取5个浓度制作;
色谱柱用毛细管柱代替填充柱;
计算时固体样品与液体样品采用不同的公式计算;
改进的方法与国标方法测定结果无显著差异;
改进的方法省时、易操作,更科学规范,适于批量样品的检测.
闲鹤野云
楼主自己先尝试翻译一下,然后我们来帮你改进,也是大家学习的过程。
glzjssxl
原文由 ruojun 发表:
主要是专业英语水平太差劲了.憋了好久才憋出这么点,烦请各位帮忙修改!
第一句:To improve the National Standard Method of Sodium Cyclamate.
第二句:此句实在不会!
第三句:The standard cure  were made by 5 series of concertration.
第四句:replaces the fill column with the capillary column.
第五句:Solid sample and liquid sample adopt a different formula calculation while computing.
第六句:The results of the improved method and the national standard didn't remarkable difference.
第七句:The improved method  saves time, it is easy to operate ,more science and norm, it's suitable for the examination of batch quantity sample.
闲鹤野云
原文由 glzjssxl 发表:
第一句:To improve the National Standard TEST Method FOR of Sodium Cyclamate.
该帖子作者被版主 redanqi5积分, 2经验,加分理由:多谢应助
闲鹤野云
第二句:此句实在不会!
样品处理时以静置取代吸出正己烷层离心
Samples were treated by settlement instead of centrifuge of Hexane layer
闲鹤野云
第三句:标准曲线取5个浓度制作;
The standard cure  curve was were made prepared with by 5 series of concertrations concentrations.
何当奇
闲鹤野云
第四句:色谱柱用毛细管柱代替填充柱;
packed column was replaced by capillary column
闲鹤野云
第五句:计算时固体样品与液体样品采用不同的公式计算;
Test results were calculated with different methods for solid samples and liquid samples respectively
闲鹤野云
第六句:改进的方法与国标方法测定结果无显著差异The results of the improved method and the national standard didn't remarkable difference.
There was no significant difference in test results between the improved method and the national standard method.
闲鹤野云
第七句:改进的方法省时、易操作,更科学规范,适于批量样品的检测.The improved method  saves time, it is easy to operate ,more science and norm, it's suitable for the examination of batch quantity sample.
ruojun: 留下这个大家看看如何翻译和修改???
