社区=冬季=回复于2008/05/27
真的可以吗?
learner1999回复于2008/05/27
你这原本应该是汉译英吧?"it may take two minutes before the flow pass through this valve","once the valve is warmed"
poorlittle回复于2008/05/27
My understanding, from literal point of view only, is that in order to ensure a stabilized flow, the valve should be pre-heated before allowing the fluid to flow through the valve, and it will take about 2 minutes for this pre-heating procedure.
需等约两分钟才可让流动相通过此阀
需等约两分钟才可用此阀
原文由 chengjingbao 发表:
NOTE: The flow control valve is a miniature thermal valve. On power up the valve is cold. It may take up to two minutes before to have flow trough this valve 。 Once the valve is warm the flow will stabilize. If you put the flow set point to 0 cc for a
while the valve will cool down again.
注意:流量控制阀是一个微型热导式调节阀。启动时,阀是冷的。在有流量通过这个阀之前两分钟,它开始运行。一旦阀被加热,流量将可以稳定。如果你将流量设定为0 CC,热导阀将再冷下来。
请各位专家再帮我看看这句话,特别是划线部分,它很重要,我翻的对不对?!!先谢谢各位啦!
原文由 learner1999 发表:原文由 chengjingbao 发表:
