主题:【原创】大家帮忙指导一下,看有没有不当(在线翻译工具翻译的)
浏览0 回复7 电梯直达
智慧的弟弟
广东省深圳市宝安区石坡矿区环境影响评价
摘要:为合理保护、适度开发、有效利用矿产资源,将矿产资源的开发利用方式从粗放型向集约型转变,同时改进矿产资源的开发技术,实现矿产资源的开发利用与环境保护良性循环。依据《深圳市矿产资源总体规划(2002~2010)》和环保法律法规、标准,对原广东省深圳市宝安区石坡矿区进行工程及污染分析、确定主要污染源及污染物排放情况;开展评价区域自然环境、社会环境和环境质量现状调查和确定工程实施影响的要素和主要环境保护目标;对项目实施可能造成的环境影响进行预测和评价,确定了影响范围和程度和可能存在的环境污染问题,提出合理可行的控制污染和保护环境的措施与对策;预测了区域环境的承载能力及区域开发建设对环境的影响,提出削减各种不利影响的措施和控制对策。通过对规化方案的优化分析,提出有利于区域社会、经济与环境协调发展的战略对策及规划总体方案,并从环境保护的角度论证项目建设的可行性,为工程建设和环境管理提供科学依据。
关键字:石坡矿区;良性循环;环境影响评价;预测;规划
Abstract : For reasonable protection and appropriate development, effective utilization of mineral resources, mineral resources development and utilization pattern from extensive to intensive change, while improving the development of mineral resources, to achieve the development and utilization of mineral resources and environmental protection positive cycle. Based on "Shenzhen City of mineral resources master plan (2002 to 2010)" and environmental protection laws and regulations, standards, the original Guangdong Province, Shenzhen Baoan District Shipo mining areas and pollution of the project, identify the main sources of pollution and emissions of pollutants, conducting evaluations of regional The natural environment, social environment and the environmental quality of the investigation and identify the factors affecting the implementation of projects and major environmental protection objectives; implementation of the project the potential environmental impact prediction and evaluation to determine the scope and extent and impact of the possible environmental pollution problems, Reasonable and practicable to control pollution and environmental protection measures and countermeasures; predicted the carrying capacity of the regional environment and regional development and construction of the impact on the environment, to reduce the adverse effects of various measures and control measures. Through the programme of the optimization analysis, is conducive to regional social, economic and environmental coordinated development of the overall strategies and planning programmes and environmental protection from the perspective of the feasibility of building demonstration projects for the construction and provide a scientific basis for environmental management .
Key words :Sipo mining area;positive cycle;Environmental effect appraisal ; Forecast;plan
红狐等翻译高手来看看
何当奇
摘要:为合理保护、适度开发Moderate exploitation、有效利用矿产资源,将矿产资源的开发利用方式从粗放型向集约型转变,同时改进矿产资源的开发技术,实现矿产资源的开发利用与环境保护良性循环。
Abstract : For reasonable protection ,moderate exploitation, effective utilization of mineral resources, the exploitation and utilization of mineral resources has been changed from extensive to intensive, furthermore the exploitation technology of mineral resources has been improved, to balance the exploitation and utilization of mineral resources and environmental protection.
非常拗口
智慧的弟弟
原文由 redanqi 发表:
非常拗口
红狐帮忙翻译下
智慧的弟弟
怪侠一点红
___________________________________________________________
Keyword: Shipo mining area; benign cycle environmental impact assessment, prediction, planning
怪侠一点红
原文由 redanqi 发表:
非常拗口
Abstract: In order to protect the reasonable and appropriate development Moderate exploitation, effective utilization of mineral resources, mineral resources development and utilization pattern from extensive to intensive change, while improving the development of mineral resources, to achieve the development and utilization of mineral resources and the virtuous cycle of Environmental Protection
智慧的弟弟
poorlittle
原文由 tanghuizhi01 发表:
摘要:为合理保护、适度开发、有效利用矿产资源......
不知“适度开发”是不是“可持续发展”(sustainable development)的同义词?
Last edit by poorlittle
