After many years of use and based on gas quality, there are sometimes some deposit build-up on the cell's internal walls. This deposit will reduce light transmission. It is possible to clean the cell with the Contrôle Analytique cell cleaning kit. This kit provides the needed hardware to
circulate a chemical solution in the cell which will remove the deposit. Chemical solution is also included.
使用多年以后,基于气体的质量,会有一些沉淀物沉积在检测池内壁上。沉淀导致光传导的减少。这时需要用CA的成套清洁工具,对检测池进行清洁。成套工具提供一个必要硬件,使化学试剂在检测池内溶解流通,溶解掉沉淀物并带走它。化学试剂也同样流走掉。
这里based on也有因…而….的意思,指因气体质量(好坏)。这些沉积将减少光传导。 可以用CA的检测池配套清洁工具,对检测池进行清洗。此配套清洁工具提供必要的硬件以在检测池内循环一可除去沉积的化学溶液。化学溶液也包括在(配套工具)内
