Forging, cold 冷模
Forging, flat-die 1 平模锻造 2 平模
Forging, hammer 鎚锻
Forging, hand 手工锻造
Forging, high-energy-rate 高能率锻造
Forging, high-velocity 高速锻造
Forging, hot 热锻
Forging, machine 机械锻造
Forging, open-die1 开模锻造2 开模锻件
Forging, pancake 扁圆锻件
Forging, press 压机锻造
Forging, roll 轧机锻造
Forging, smith 手工锻造
Forging, upset1 锻粗锻造2 锻粗锻件
fork 铁叉
form chamfering 整形去角取面
Formability 成形性
formal verification 正式验证
formatter 格式编制器
Forming 成形
forming gas 组成气体
Forming, bulge 胀大成形
Forming, compression 压缩成形
Forming, contour roll 型辊成形
Forming, creep 潜伸成形
Forming, drop hammer 落鎚成形
Forming, electrohydraulic 电液成形
Forming, electromagnetic 电磁成形
Forming, explosive 爆炸成形
Forming, high-energy-rate 高能井成形
Forming, hydraulic 液压成形
Forming, magnetic pulse 电磁震动成形
Forming, multiple-slide 多滑块成形
Forming, press 压机成形
Forming, press-brake 折条机成形
Forming, radial-fraw 径拉成形
Forming, rubber-diaphram 橡胶膜成形
Forming, rubber-pad 橡胶垫成形
Forming, rubber-punch 橡胶冲成形
Forming, shrink 收缩成形
Forming, stretch 拉伸成形
Forming, three-roll 三辊成形
Forming, wacuum 真空成形
Forming, wire 线料成形
Forms 模板
Forrester flotation machine 富尔斯特浮还机
forsterite 镁橄榄石
Forsterite (Mg2SiO4)矽酸镁石
forward annotation 正向注解
Forward extrusion 顺向挤制
Forward spinning 顺向旋挤
Forward welding 前进熔接
Foucault current method 傅科电流法
Fouling 积垢(船底海藻贝壳)
fouling index(FI) 污浊指标(FI)
Fouling resistance 防垢性(铅底)
Foundation 基础
Founder 铸工
Founding 铸造
Foundry1 铸造2铸造场
Foundry coke 铸焦
Foundry defects 铸疵
Foundry ladle 铸造浇斗,铸造盛通
Foundry losses 铸造损耗
Foundry pig 铸造生铁
Foundry pig iron 铸造用生铁
Foundry returns 回炉料
Foundry sand 铸砂
Foundry type metal 手植活字合金
four (point)
probe method 四(点)探针法
Four-high mill 四辊巴机,四重式轧机
four-way type 四方向方式
Fourier transform infrared spectroscopy 傅立叶转换红外光谱学
four(point)probe method 四(点)探针法
Fractional crystallization 分段结晶
Fractography 断口型像学
Fracture mechanics 破断力学,破坏力学
Fracture stress 破断应力
Fracture surface 破断面
Fracture test 破断试验
fracture toughness 破裂韧性
Fracture transition 脆断转移[温度]
Frame filter press 框式压泸机
frame memory 视帧记忆器;图框记忆器
Frame work structure 构架结构
framework 架构
Francium (Fr, 87)金法
Frand-Read source 法一瑞式[差排]源
Frank partial dislocation 法兰克部份差排
Frary metal 法拉钡合金(一种铅钨钡合金)
Free carbon 游离碳
Free cementite 游离雪明碳铁
free cutting brass 易切黄铜
free cutting bronze 易切青铜
Free cutting steel 易切钢
Free electron 自由电子
free energy 自由能
Free ferrite 游离肥料铁
Free lime 游离石灰
Free water 游离水份
Free-cutting metal 易切金属
free-flow bender 开放弯曲机
freeze-casting 冻铸法
freezing 冷凝,冻结凝固
freezing and thawing test 冻结融解试验
Freezing cuve 冷凝曲线
Freezing method 冷凝法
Freezing point1 凝固点; 2 冰点
Freezing range 凝固范围
French chalk 法兰西白呈(即滑石3
MgO4SiO2、H2O)
French metal 法兰西金属(一种精炼锑)
French process 法兰西法(一种提锌法)
Frenkel defect 佛兰克缺陷(晶格缺陷)
Fresh water 淡水
Fretling corrosion[ 紧压]磨蚀,移擦腐蚀
friction element 摩擦元件
Friction oxidation 摩擦氧化
friction pressfriction-screw press Friction sawing 摩擦锯切
Friction screw press 摩擦螺杆压机
Friction welding 摩擦熔接
Frictional loss 摩擦损耗
frifluoroacetylnitrile 亚硝酸三氟乙醯
Fringe 晕纹
frit 熔块;玻料
fritted glass ware 玻釉玻璃器
fritted glaze 熟釉;玻料釉
fritted porcelain 玻料瓷
Fritting1 烧结(同sintering) 2 上釉料
frizzling 绉缩(陶)
frog ring 辙叉环
Fromont test 傅瑞孟[冲击]试验
front end design 前端设计
front side reference method 前侧基准法
Front slagging 前渣法
Frontier alloy 佛兰提合金(一种铝锌合金)
frost glass 磨砂玻璃
Froth flotation 泡漆浮选
Fry's reagent 傅蕊族剂
fuel cell 燃料电池
fuel cell stack 燃料电池堆
Fuel cycle 燃料循环
Fuel element 燃料元件
Fuel fabrication 燃料构制
Fuel oil 燃料油
Fuel ratio 燃料比
Fuel reprocessing 燃料再处理
Fugacity (fugasity)1 挥发度 2 挥发性
Full annealing 完主退火
full automatic growing furnace 全自动成长炉
full cutting 全切割
Full hardening 完全硬化
Full insert 整体嵌件
Full mold process 全模法
full site 全体区分地段
Full-killed steel 全静钢
Full-mould casting process 金模铸造法
Fuller 半圆型鎚
fuller earth 漂白土
Fuller's ideal curve 富乐理想曲线
Fullering 歛缝,填隙
fullering bar 填隙棒
Fullering fmpression 歛缝型
Fully-killed steel 全静钢
Fulminates 雷酸盐(不稳定易爆材料)
fume 烟气
function test 功能测试
Functional ceramics 功能陶瓷
functional description language 功能记述语言
functional schematic editor 功能检图编辑器
Fundamental vector Furnace 基本向量炉
Fundation translation vector 基本平移向量
funerary ware 明器
furnace angle 炉体倾斜角
furnace annealer 电热炉退火处理机
furnace lift travel 炉移动行程
Furnace lining 炉衬
furnace tube cleaning equipment 炉心管洗涤设备
Furnace, baking 烘焙炉
furnace, batch [type] 批式炉
furnace, bell-type 钟罩式炉
furnace, bogie hearth 钟罩式炉,拖车式炉
furnace, box 箱式炉
Furnace, car bottom 车底式炉
Furnace, chain type 链式炉
Furnace, continuous 连续式炉
Furnace, continuous-strand 连绩回式炉
Furnace, conveyor (conveyer)输送带炉
Furnace, direct arc 直接电弧炉
Furnace, high frequency 高周波电炉
Furnace, holding 保温炉
Furnace, indirect arc 间接电狐炉
Furnace, lift off cover 离盖式炉
Furnace, overhead conveyer 高吊输送炉
Furnace, pit 坑式炉
Furnace, preheating 预热炉
Furnace, pusher 推式炉
Furnace, remelting 再泰炉
Furnace, roller hearth 滚子炉
Furnace, rotary-hearth 转膛炉
Furnace, screw feed 螺旋送料炉
Furnace, slot-type 槽式炉
Furnace, tunnel 隧道炉
furnace, walking beam 动梁炉
fuse data 熔丝资料
fuse link 链丝熔丝
Fuse-quench process 熔化急冷法
Fused alumina 熔凝铝氧
Fused quartz 熔凝石英
Fused sand 熔砂
fused silica 熔矽石
Fused zone 泰融带
Fused-cast refractory 熔铸耐火材料
fused-salt electrolysis 泰盐电解
Fused-silica frick 熔凝矽砖
Fused-silica refractory 泰凝矽质耐火材料
Fusible alloy 易熔合金
Fusible pluger 易熔塞
Fusing pyrometer 融点高温计
fusion1 熔化,熔解 2 熔合(核子)
fusion casting 熔铸法
Fusion of packing materials 填料熔合
Fusion penetration 熔融穿入
Fusion point 熔融点
Fusion range 熔融区
Fusion sawing 熔融锯
Fusion temperature 熔融温度
Fusion welding 熔融泰接
fusion-flow test 熔流试验(搪瓷)
fuzzy texture 疏松结构(搪瓷)
