俺也来试一段:
2.Gold (Au)
The chemical stability of Au is very similar to that of Hg. The following suggestions may be helpful:
Nitric acid solutions of Au at the low ppm and ppb levels are not stable. Use HCl matrices.
Do no use Pt crucibles when ashing samples containing Au. Au will alloy with the Pt.
When measuring Au in the presence of significantly greater amounts of Pt using
ICP-MS, be aware of the resolving capability of your instrument.
金(Au)
Au和Hg的化学稳定性非常相似。以下的建议也许有用:
Au的硝酸溶液在低的ppm和ppb级的水平下是不稳定的。使用HCl基体。
当灰分样品含有Au的时候不要使用Pt坩锅。Au将和这些Pt融为合金。
在Pt更大量存在下使用
ICP-MS的时候测定Au,注意你的仪器的溶解性能。
