原文由 happyjyl 发表:
windows which are not rainproof shall be provided with a window -cover which overlaps the window on all sides by at least 10 cm ,on the periphery, the cover shall be provided with attachment points (e.g.toggles)at maximum intervals of 35 cm,these requirements do not apply when zip fasteners are used.
不防雨的窗户应配备窗套。窗套(的边长)应比窗户每一边(的边长)至少多出10cm。窗套的外围应有联结点(如套索钉),联结点的最大间距为35cm。(即各联结点之间的间距不能超过35cm。)当使用拉链(即窗套上有拉链)时,这些要求不适用。
下面的网站对理解什么是window cover比较有帮助:
http://www.hudik-kapell.se/english.htm
http://picasaweb.google.com/jonziomek/JonInJerusalemAndCairo02/photo#5132738622378346706
原文由 ruojun 发表:
