原文由 sino_academy 发表:
1、Mutual interference coefficients obtained for 639 emission lines of 68 elements in routine analysis by ICP-AES
Yûetsu Danzaki, Kunio Takada, Kazuaki Wagatsuma and Masaoki Oku
In our previous report [1], a practical method to obtain spectral interference coefficients and to select analytical lines in ICP-AES has been suggested...
Fresenius' Journal of Analytical Chemistry, Volume 364, Number 6 / 1999年7月
2、Accurate and rapid estimation on spectral interferences in routine analysis by ICP-AES: use of mutual interference coefficients
A practical method to estimate spectral interferences and to select optimum analytical lines in ICP-AES is suggested. Depending...
Fresenius' Journal of Analytical Chemistry, Volume 361, Number 5 / 1998年7月
3、Example of a technique for evaluation of interferences caused by complicated sample matrix elements in ICP-AES determination
P. Hautaniemi and Rose Matilainen
An example of a useful and rapid procedure for the evaluation of interferences caused by complicated sample matrices in inductively coupled plasma atomic emission spectrometry...
Fresenius' Journal of Analytical Chemistry, Volume 370, Number 1 / 2001年5月
