遇到一段关于X-衍射的英文,不知道怎么翻译,求行家指导一下吧,在这里先谢过了,原文如下: Crystallographic data were collected using a Bruker SMART CCD (charge coupled device) based diffractometer equipped with an LT-2 low-temperature apparatus operating at 213 K. A suitable crystal was chosen and mounted on a glass fibre using grease. Data were measured using omega scans of 0.3 ° per frame for 30 seconds, such that a hemisphere was collected. A total of 1271 frames were collected with a maximum resolution of 0.75 Å. The first 50 frames were recollected at the end of data collection to monitor for decay. Cell parameters were retrieved using SMART software and refined using SAINT on all observed reflections. Data reduction was performed using the SAINT software which corrects for Lp and decay. The structures are solved by the direct method using the SHELXS-97 program and refined by least squares method on F2, SHELXL-97, incorporated in SHELXTL V5.10. The structure was solved in the space group P2 1/c (# 14) by analysis of systematic absences. All non-hydrogen atoms were refined anisotropically. Hydrogens were calculated by geometrical methods and refined as a riding model. The crystal used for the diffraction study showed no decomposition during data collection. All drawings are done at 50% ellipsoids. In this analysis, there is ¼ of a CHCl3 molecule per molecule of AGF667. 请多支援!谢谢!
Crystallographic data were collected using a Bruker SMART CCD (charge coupled device) based diffractometer equipped with an LT-2 low-temperature apparatus operating at 213 K. 使用基于Bruker SMART CCD (charge coupled device)的色差仪采集晶图数据,该色差仪配备了213K下运行的LT-2低温设备。
A suitable crystal was chosen and mounted on a glass fibre using grease. Data were measured using omega scans of 0.3 ° per frame for 30 seconds, such that a hemisphere was collected. 选择合适的晶体并用油脂附着在玻璃纤维上。按每幅0.3 °用omega扫描仪测量数据30秒以采集半个圆的数据
