主题:【求助】一段英文文字的意思
826beibei
Using volatile acid standard mix (10 mM in deionized water) containing acetic acid,
formic acid, propionic acid, isobutyric acid, butyric acid, iso-valeric acid, n-valeric acid,
iso-caproic acid, n-caproic acid and heptanoic acid, 20 mg/L and 10 mg/L stock
solutions were prepared in deionized water. On preparing such solution, mass of acetic
acid was taken in account and later concentration of other acids was calculated based on
that concentration.
请问怎么用乙酸的浓度来计算其他酸的浓度?
影子
使用包含有乙酸、甲酸、丙酸、异丁酸、丁酸、异戊酸、正戊酸、异已酸、正已酸及庚酸的标准混合酸(10mM水溶液),用去离子水制备20mg/L和10mg/L的贮备溶液。制备溶液时要考虑乙酸的质量,其它酸的浓度基于此浓度计算。
单凭这段话还真不知道怎么用乙酸的浓度来计算其他酸的浓度
