PERSONNEL MUST BE CERTIFIED BY HS&E PRIOR TO RESPIRATOR USE.
When fitting a new respirator, try on several brands and sizes. Different brands will fit slightly differently on your face. Respirator manufacturers usually have small, medium, and large face-pieces available. Adjust the straps so that the respirator fits tightly, but does not dig into your face or leave red marks on your
skin. The respirator should feel snug, yet comfortable.
1. Remove respirator, cartridges, and filters from plastic bags.
Check to see that gasket is in cartridge holder before screwing in
cartridges. Insert filter into retainer caps and snap onto cartridge
holder or cartridges.
2. The cartridge holders are keyed to assure their correct positioning and maintain the proper balance of the device. Make
sure they are properly positioned and seated.
3. Place respirator on face with narrow end over nose and bottom
under chin. First attach top headband around crown of head
and then bottom around neck. Adjust headbands until a tight but
comfortable fit is obtained.
4. TEST FOR TIGHTNESS: Place the palm of the hand or thumb
over the valve guard and press lightly. Exhale to cause a slight
pressure inside face piece. If no air escapes, respirator is
properly fitted. If air escapes, readjust respirator and test again.
There are two simple checks to test the seal. These are called
the positive and negative pressure fit-checks. These tests must
be done EVERY TIME the respirator is put on (see overleaf).
5. FILTERS: (a) REPLACE when breathing becomes difficult, INSERT new filters INTO retainer cap and replace cap. Generally the filter discs should be changed after eight hours of dusty exposure. (b) CHEMICAL CARTRIDGES should be replaced when the senses detect ANY abnormal condition, assuming that levels of detection by the senses do not constitute a health hazard.
6. MAINTENANCE: The respirator face piece should be cleaned daily to prevent skin irritation and for general sanitary purposes. First remove filters and cartridges. Then the face piece may be washed with a hand brush using a good detergent in warm water, rinsing, and air drying in a clean place. Some compounds considered to be suitable for disinfecting are: (1) a hypochlorite solution (50 parts per million of chlorine; immersion time: 2 minutes) (2) an aqueous solution of iodine (50 ppm iodine; immersion time: 2 minutes) (3) a quaternary ammonium solution (200 ppm quaternary ammonium compounds in water with less than 500 ppm total hardness). RINSE IN CLEAN WARM WATER AND AIR DRY. Inspect respirator daily for worn or faulty parts and
replace these at once. Proper parts supplied by the manufacturer must be used.
7. For your protection, the DUST FILTERS and CHEMICAL CARTRIDGES must
be assembled tightly, and changed frequently, according to exposure.
8. KEEP RESPIRATOR CLEAN when not in use. Store in container
provided.
