1.Title: Analysis of necking deformation behavior in high-speed in-line drawing process of PET by on-line diameter and velocity measurements
Author(s): Hahm, WG; Ito, H; Kikutani, T
Source: INTERNATIONAL POLYMER PROCESSING Volume: 21 Issue: 5 Pages: 536-543 Published: NOV 2006
Times Cited: 1
http://www.polymer-process.com/o_archiv.asp?o_id=2531143156-51&ausgabe_id=261112171949-92&artikel_id=2006111218040&task=03&j=2006&h=05&nav_id=2.Title: Effects of take-up speed of melt spinning on the structure and mechanical properties of maximally laser drawn PA9-T fibers
Author(s): Uddin, AJ; Ohkoshi, Y; Gotoh, Y, et al.
Source: INTERNATIONAL POLYMER PROCESSING Volume: 21 Issue: 3 Pages: 263-271 Published: JUL 2006
Times Cited: 0
http://www.polymer-process.com/o_archiv.asp?o_id=2531143156-51&ausgabe_id=2671131427-74&artikel_id=2671134846-62&task=03&j=2006&h=03&nav_id=
