主题:【求助】乙磷铝检测方法
浏览0 回复8 电梯直达
yangmei
最近要检测乙磷铝,查到一个日本的方法,好象很麻烦,哪位有好的检测方法,请指点一下,谢谢!
高难度啊,查不到方法,不过查出来是有机膦类杀菌剂……不知道液相能做不能
雾非雾
原文由 lnyangmei 发表:
乙磷铝肯定要用单独法,应该不会太简单的,有几种农药大家公认难检.
广东海风
原文由 lnyangmei 发表:
它的性质决定了它就是难检,很简单的方法可能性不大.毕竟又要提取还要净化的.
我在故我思
我在故我思
Determination of fosetyl-aluminium in the presence of folpet
Milinovic, J.; Lazarev, S.; Stojanovic, D.
Pesticides and Phytomedicine
2006 v. 21(2) p. 161-165
A modified spectrophotometric method for determination of fosetyl-aluminium in the presence of folper was developed. The method is based on melting samples in heating furnace at a temperature of 800-900 deg C. The residues obtained were oxidized, and phosphonate from fosetyl-aluminium was converted into phosphate by adding solutions of nitric acid and hydrogen peroxide. Phosphate was determined spectrophotometrically at 440 nm with the molibdate-vanadate reagent. Based on phosphate content (as P2O5), fosetyl-aliminium content can be determined, taking into account that three moles of P2O5 are obtained from two moles of fosetyl-aluminium. Based on the values of relative standard deviation and recovery, it may be concluded that the proposed method is relatively reproducible and accurate.
我在故我思
Potential of liquid chromatography-atmospheric pressure chemical ionisation tandem mass spectrometry for determination of fosetyl-aluminium residues in dried hops.
Poustka, J., Hajšlová, J., Holadová, K., Nováková, K.
Czech Journal of Food Sciences,  2004  (Vol. 22)  (No. 1) 24-28
Abstract:
New analytical procedure for the determination of fosetyl-aluminium in hop cones (also called "hops") was developed. Liquid chromatography-atmospheric pressure chemical ionization tandem mass spectrometry (LC-APCI-MS/MS) allowed a highly selective determination of this fungicide which facilitated the sample preparation. The sufficiently low detection limit (1 mg/kg of dried hops) with the acceptable method performance characteristics (RSD 9%, recovery 76% - at the level of 10 mg/kg) complies with the need to inspect the observance of maximal residual limit of 100 mg/kg. The application of LC-MS technique thus provided an effective way of fosetyl-aluminium determination in the complex hops matrix.
SOMS课题组
消解后测磷和铝的量,就可以推论结构!!不过是高含量的方法,容量法滴定或者是分光光度法!!
我在故我思
原文由 rljcs 发表:
楼上,有没有翻译过来的检测方法,英文的看起来比较吃力.翻译过来的别的方法也行啊.谢谢!
你好!暂时没有找到中文的相关资料,其实英文的方法不是很难理解的,都是程序式的描述。
