原文由 andy917(andy917) 发表:
我也被這樣的問題揪心著:測的7E都可以,就是鉻的檢測值在25ppm左右浮動,而且我連續做了三天,每天四平行!開始我懷疑是標樣材質不均勻,先用XRF掃後和標值差不多,接著我把它剪碎了後再均勻稱量,得到的ICP最後檢測結果依舊。還請路過的大俠指教一二!
Additional Material Information | |
Mass Fraction 1 [mg/kg] | |
Acid digestible Cr | 2.9 – 16.2 |
1) Range of results obtained by conventional acid digestion of the material in 9 laboratories. The value of the amount of acid digestible Cr depends on the sample intake as well as on digestion conditions (acid mix, temperature, pressure). |
原文由 damoguyan(damoguyan) 发表:原文由 andy917(andy917) 发表:
用微波多消解几遍,不要看消解清了(眼看澄清不算,继续消解几遍)
我用一个比较差的微波一次消解眼看是澄清的,但测试结果老是20-60ppmCR(很多次都这样)
后来消解2遍,得到CR108PPM,有时间大家也多消解几次试试。。。。
EC681K证书中有以下说明,CR的值在20-80之间也是正常的:
你这消解用什么试剂,什么升温程序,能将里面的CR做的这么好,108PPM?
Additional Material InformationMassFraction1
[mg/kg]
Acid digestible Cr2.9 – 16.2
DESCRIPTIONOFTHESAMPLE
The sample consists of approximately 100 g granulate of low-density polyethylene (LDPE) spiked with various pigments to obtain the desired element contents.
Note: A significant fraction of Cr is in the form of Cr2O3. Not all digestion methods will therefore result in full digestion.
