主题:【求助】请教分析选区电子衍射图谱方面的知识
浏览0 回复2 电梯直达
fengshouai
作者分析电子衍射图谱(见附件)后认为,纳米线沿【0001】取向,有共面(2-1-10)和(01-10),详见下列英文文字(从论文中摘录)。[0001]和(2-1-10)很好理解,因为电子衍射图谱中标有,但(01-10)就很奇怪了,图中并没有啊,作者是如何得出的?
    Transmission electron microscopy shows that the individual
nanowires are single-crystal wurtzite ZnS, with trace amounts of
CdSe possibly interspersed within the lattice. From the diffraction
pattern recorded from a bundle (Figure 2a,b), the single-crystal
pattern clearly indicates the orientation alignment among all of the
nanowires in the bundle along [0001], and they share the same
side surface of (2-1-10) and a top surface of (01-10).
蓝莓口香糖
在六方晶系中,同时与(0001)和(2-1-10)垂直的晶面就是(01-10),画个晶胞的图就看出来了。附带的衍射谱也是(01-10)带轴,正好就是上表面法线方向。
bulebutterfly
