三。varian 的cary 300
瓦里安的Cary 300
1.Varian’s Cary 300 has a premonochromator, extending its range past 5.0 absorbance units (Abs). The Cary 100 has a working range past 3.5 Abs.
瓦里安公司的Cary 300具有前置单色器,将吸光度线性范围扩展到5Abs。Cary 100的线性范围是3.5Abs。
2.A phase locked wavelength drive prevents peak shifts and peak suppression at high scan speeds.
相位锁定波长驱动技术可以防止仪器在快速扫描时吸收峰的偏移。
3.Variable slits provide optimum control over spectral resolution.
连续可调的带宽可以优化样品的光谱分辨率。
4.The sealed optics prevent exposure to corrosive environments.
密封的光路系统可以防止外界腐蚀性气体进入光路中。
5.Quartz overcoating protects the optics from the environment and allows cleaning without damage to their refective surface.
石英镀膜的光学器件可以防止环境对光学器件的损害,并且清洁时不破坏光学件的反射率。
6.Although the Cary 100 and 300 both have a double beam design you can elect to operate them in single, double,or dual-single beam modes.
虽然Cary 100和Cary 300都是双光束的仪器,但是您可以选择让仪器工作在单光束、双光束、和实时双光束等模式下。
7.The Accessory Controller offers centralized accessory control, making it easier to service the instrument because of the single set of accessory electronics. In addition,the controller allows you to communicate with non-Varian accessories.
附件控制器提供统一的附件控制程序,便于仪器控制各种附件。并且,允许可以与非瓦里安生产的附件通讯。
8.The large sample compartment gives you more fexibility in sample size.
大样品仓便于多种尺寸样品的测试。
9.Double choppers ensure that the sample and reference beam strike the detector at the same point, eliminating any errors due to non-uniformity of the detector.
双斩波器确保样品光路和参比光路聚焦在检测器的同一点上,降低检测器不均一性对测试结果的影响。
Cary 300中文样本
