Solid-State NMR of Polymers
NMR spectroscopy has emerged as one of the most important methods for the solid-state characterization of polymers. This report gives an overview of the methods and applications of NMR to relevant polymer problems with an emphasis on how NMR can be used for materials characterization and to understand structure-property relationships in polymers. This report is of interest to both the chemical and pharmaceutical industry.
The review begins with a discussion of the fundamental principles which underpin solid-state NMR, before leading onto the experimental methods involved, including magic-angle sample spinning, and multi-dimensional NMR. A section is then devoted to polymer structure and conformation, including information on semicrystalline polymers. Polymer morphology is detailed, with a focus on polymer crystallinity and blends. The review is completed with a discussion on polymer dynamics, with particular emphasis on semicrystalline, as well as amorphous, polymers.
The book comprises a concise expert overview, accompanied by an indexed section containing approximately four hundred references and abstracts from the Rapra Abstracts database. These will provide the reader of this report with a valuable reference for further information relating to the study of polymer microstructure using solid-state NMR.
