原文由 lotus_sum 发表:
原文中还有依据话是说any product or any part of product, 从这个角度上来说产品中应用的任何助剂均不得含有超过1000ppm的DMF!此时,和REACH中SVHC界定的差别在于从单一材料而不是仅从整理角度进行评价!
是0.1ppm."
The presence of DMF in products should be determined
against the maximum limit of 0,1 mg DMF per kg of
product or part of the product.
Accordingly , the analytical method employed should be
able to reliably quantify 0,1 mg DMF per kg of product
or part of the product."
1000ppm 已经是每公斤一克了。您是笔误吧。
