原文由 learner1999 发表:
源自于下面:
NON-LATEX USERS: Editable source files must be uploaded at this stage. Tables must be on separate pages after the reference list, and not be incorporated into the main text. Figures should be uploaded as separate figure files.
LATEX USERS: For reviewing purposes you should upload a single .pdf that you have generated from your source files. You must use the File Designation "Main Document" from the dropdown box.
