主题:【原创】新产品、新技术介绍 Q-control
浏览0 回复6 电梯直达
ative
提高tapping mode的Q (品质因数),降低针尖和样品的相互作用力,从而提高分辨率和稳定性。这个附件是一个德国公司最新开发出来的。
In scanning force microscopy often dynamic modes are used, in which in contrast to static modes the micromechanical probe is interacting with the sample surface just temporary. Thereby in principle it is possible to reduce the forces exerted by the probing tip on the sample. The Q-Control module is a modification or hardware add-on to scanning force microscopes that comprises an additional feedback circuit. It allows to increase the effective quality factor of the dynamic system. As a results a further significant reduction of the interaction forces between the probe and the sample can be achieved.
Various applications show that many highly sensitive surface structures, in particular ultrathin organic layers or biological samples in liquids, can only be non-destructively imaged and characterized by using such an active feedback circuit. Furthermore, Q-Control often allows to improve the maximum achievable resolution in topographical measurements and to increase the overall sensitivity for magnetic or electrostatic fields.
〓疯子哥〓
清风侠
ative
这个技术不是很新,不过可靠的产品还是比较新,国内好像纳米中心有。
这是德国一个小公司做的。
hitttr
大侠说得对,Q-control不算是一种新技术了。
在SPM的一些应用领域,Q-control是一种非常必要的技术,
例如大气环境下的非接触模式,
一般情况下都需要用Q-control来提高悬臂的品质因子,
这样才能在非接触区间稳定成像。
现在很多商业化的SPM都配备有Q-contol技术。
此外用户如果需要的话,可以自己购买Q-control控制器,
将SPM信号通过q-control控制器进行品质因子调节。
guolinhao
Q control 是什么意思?是不是扫描之前做好Q曲线 请教了
chenga
