原文由 ssh110 发表:
敲击模式不用说,大家伙都明白。你可以把编辑给你的原话贴出来吗?
谢谢版主,原话是这样的:
4) As for the surface morphology:
The domain size in all pictures seems to be quite larger than the expected value from the molecular weight of the copolymer. The size of each domain was found to be a few hundreds of nanometer that cannot be reached using the copolymer having Mn of 20,000 – 30,000.
Author only showed height images of AFM. The phase images of AFM using tapping mode was also obtained simultaneously. Author concluded that the bright region was assigned to the PHEMA rich phase. The phase images provide the information on which regions are PHEMA or PtBA rich phases because PHEMA and PtBA are hard and soft at
room temperature, respectively.
