在学习扫描电镜/能谱仪时,对dead time 的意思不能真正了解,原想发个帖子向版主请教,后来决定在网上先查一下,结果还真没有让我失望,解决了我的困惑。
自从加入仪器信息网以来,原先主要是在资料中心、分析方法、和讲座里找一些资料,后来开始在论坛里看大家发的帖子,收益很大。特别是前几天有困难向天黑请闭眼(shxie)斑竹请教,给予我很大的帮助,深表感谢,也希望自己能有机会帮助别人。我把这次查到的资料传上来,与大家共享,希望大家能喜欢这个资料。
因为无法用附件,资料有比较长,只能分次传了。
【已经整理为附件上传】
相关附件Glossary
A | B | C | D | E | F | G | H | I | K | L
M | N | O | P | R | S | T | U | W | X | Z
A
ABSORBED DOSE
Absorbed dose is the amount of energy deposited in any material by ionizing radiation. It is a measure of energy absorbed per gram of material. The SI unit of absorbed dose is the gray. The special unit of absorbed dose is the rad.
ACCURACY
The degree of agreement between an individual measurement or average of measurements and the accepted reference value of the quantity being measured. See also precision.
ACTIVATION ANALYSIS
A method of chemical analysis (for small traces of material) based on the detection of characteristic radionuclides in a sample after it has been subjected to nuclear bombardment.
ADC
Analog to Digital Converter. A device which changes an analog signal to a digital signal.
AIM
Acquisition Interface Module: a type of multichannel analyzer.
ALARA
Since exposure to radiation always carries some risk, the exposure should be kept "As Low As Reasonably Achievable", as defined by 10 CFR 20.
ALGORITHM
A set of well-defined rules for solving a problem.
ALPHA PARTICLE [Symbol: a]
A particle made up of two neutrons and two protons; it is identical to a helium nucleus and is the least penetrating of the three common types of radiation (the other two are beta particles and gamma rays), being stopped by a sheet of paper or a few centimeters of air. An alpha-emitting substance is generally not dangerous to a biological system, such as the human body, unless the substance has entered the system. See decay.
AMPLIFICATION
The process by which weak signals, such as those from a detector are magnified to a degree suitable for measurement.
ANALOG MULTIPLEXER
An electronic instrument that accepts several inputs and stores each one in a separate section of MCA memory. Also called a mixer/router.
ANNIHILATION RADIATION
Radiation produced by the annihilation of a positron and an electron. For particles at rest, two photons with an energy of 511 keV each are produced.
ANTICOINCIDENCE CIRCUIT
A circuit with two inputs. The circuit delivers an output pulse if one input receives a pulse within a predetermined time interval, usually on the order of milliseconds, but not if both inputs receive a pulse. A principle used in pulse height analysis. See also coincidence circuit.
AREA
The number of counts in a given region of a spectrum that are above the continuum level.
ASCII
An acronym for American Standard Code for Information Interchange, a method for encoding alphabetical, numeric, and punctuation characters and some computer control characters.
ATTENUATION CORRECTION
Correction to the observed signal for the attenuation of radiation in a material between the sample and the detector or within the sample itself.
B
BACKGROUND RADIATION
Radiation due to sources other than the sample, such as cosmic rays, radioactive materials in the vicinity of a detector or radioactive components of the detection system other than the sample.
BACKGROUND SUBTRACTION
The statistical process of subtracting the background level of radiation from a sample count.
BACKSCATTERING
The process of scattering or deflecting into the sensitive volume of a measuring instrument radiation that originally had no motion in that direction. The process is dependent on the nature of the mounting material, the shield surrounding the sample and the detector, the nature of the sample, the type of energy of the radiation, and the geometry. See also scattering.
BASELINE
In biology, a known base state from which changes are measured. In electronics, a voltage state (usually zero volts) from which a pulse excursion varies.
BECQUEREL [Symbol: Bq]
The SI unit of activity, defined as one disintegration per second (dps).
BETA PARTICLE [Symbol: ß]
An elementary particle emitted from a nucleus during radioactive decay with a single electrical charge and a mass equal to 1/1837 that of a proton. A negatively charged beta particle is identical to an electron. A positively-charged beta particle is called a positron.
BIOLOGICAL HALF-LIFE [Symbol: Tb]
The time required for a biological system to eliminate half of the amount of a substance (such as radioactive material) by natural processes. Compare effective half-life and half-life.
BREMSSTRAHLUNG
Radiation produced by the sudden deceleration of an electrically charged particle when passing through an intense electrical field.
