主题:【分享】大体积进样技术在气相色谱-质谱法测定二噁英类化合物中的应用
浏览0 回复4 电梯直达
kenneth06
摘要:利用大体积进样技术(1arge volume injection,LVI),结合气相色谱一质潜方法对二 英的测定效果进行了研
究。同时与传统分流/不分流进样技术进行丁对比。对进样体积为1,5,10,25,50和100 L的色谱图进,彳了分析:
研究表明使用大体积进样方式,在不影响色谱分离度的同时,大幅度提高了分析灵敏度。通过对土壤样品的检测,
证明该方法可以用于环境样品的实际测定。
关键词:气相色谱一质谱法;大体积进样;二嗯英;环境样品
大体积进样技术在[url=https://insevent.instrument.com.cn/t/Mp]气相色谱-质谱法测定二噁英类化合物中的应用2.pdf[/url]
kenneth06
以下是几篇国外关于大体积进样分析二噁英的文章
Development of a Method for Dioxin Analysis of Small Serum Samples with Reduced Risk of Volatilization
National Institute for Environmental Studies, 16-2 Onogawa, Tsukuba, Ibaraki 305-8506, Japan, and GL Sciences Inc., 237-2 Sayamagahara, Iruma, Saitama, 358-0032, Japan
Development of a Method for Dioxin Analysis of Small Serum Samples with Reduced Risk of Volatilization.pdf
kenneth06
Evaluation of automated direct sample introduction with comprehensive two-dimensional gas chromatography/time-of-flight mass spectrometry for the screening analysis of dioxins in fish oil
Eunha Hoha, Steven J. Lehotaya,∗, Katerina Mastovskaa, Janice K. Huweb
a US Department of Agriculture, Agricultural Research Service, Eastern Regional Research Center, 600 East Mermaid Lane, Wyndmoor, PA 19038; USA
b US Department of Agriculture, Agricultural Research Service, Biosciences Research Laboratory, 1605 Albrecht Boulevard, Fargo, ND 58105, USA
lhlliyue
symmacros
请问楼主,在“大体积进样技术在气相色谱-质谱法测定二噁英类化合物中的应用”文章中样品用什么溶剂溶解?
