In the following years, several groups investigated wavelength modulation, using AC scanning, oscillating interferometers or a combination of optical scanning and mechanical chopping in order to improve the signal-to-noise ratio (SNR) and the sensitivity of continuum source
AAS (CS
AAS). In the latter work, Elsner and Winefordner reported analytical curves that were linear over at least three orders of magnitude, and detection limits that were close to the theoretical values.
A kind of turning point in this early phase of CA
AAS was the work of Keliher and Wohlers who for the first time used a high-resolution echelle grating spectrometer for CS
AAS. The major limitation at that time was the 150W xenon lamp used as the continuum source, which had only a relatively low energy at wavelengths below 320nm, where most of the elements have their most sensitive lines. This work was then continued over the next 25 years by the groups of O’Haver and Harnly, who continuously improved the system, introducing wavelength modulation, a pulsed continuum source and a linear photodiode array detector. They also described the first, and up until now only, functional simultaneous multi-element atomic absorption spectrometer with a continuum source (SIMAAC), and showed the applicability of this system for a variety of practical analytical problems using flame and graphite furnace atomization. The only other ‘simultaneous’ CS
AAS instruments describe in the literature used photodiode array detectors that covered a spectral range of 2.5nm and 10nm, respectively, and only elements that had absorption lines falling within this narrow spectral window could be detected simultaneously. This approach, obviously, cannot be considered a true simultaneous multi-element system.
